Duotherm briskair 57908-521 on a BIGFOOT trailer, during a electric storm my A/C start by himself....and all swtich was OFF..??? I unplugged the main wire....I plugged it back and now the Fan is working but no COOL air, the compressor never start....I change the Thermostat (3100781008)...same problem ...what should I do?? is there a reset? TKS!
  • 161 Answers
SOURCE: air conditioner
The lightening may of caused a surge and your unit may have it's own protector that resets and comes back on after a time frame programed into it.
Posted on Aug 08, 2007
relaga58
  • 158 Answers
SOURCE: DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
Posted on Jun 01, 2009
  • 587 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
motor1258
  • 6674 Answers
SOURCE: I have a DuoTherm BriskAIr 13.5K BTU. The Dometic
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Posted on Jul 08, 2009
Testimonial: "thanks for the link. info solved my problem."
SOURCE: duo therm air conditioner that the compressor will not start
your switch should be oopen but when it reaches 41 degrees it should open so the system shuts off before it damages the compresor by sludging it, i have the same unit and my compresor runs for 5 seconds and shuts off, i checked the amp draw at the compresor and it draws 21 22 amps trying to start after the initial 5 second run, but it wont come on againts a load so the comprresos equilizes and tries to start over again with out positive results. i bipass the external obverload on top of compresor terminals area, still no fix yet, the relay on the control board continious to send power to the compresor and still draws , so if there is a problem with the control relay i would open up and dont send power to the compresor so i dont think is the relay, i am a a/c service man for
35 years and do this for a living still today, by experience i think it is the compresor gone bad but will try by passing the relay just to see what happens, also it could be bad capacitor since it have a hard start relay and start capacitor (black )also a run (silver ) capacitor they check ok, there is no way to check the charge unles you install a saddle tap to check presures and rechage this unit i think the compresor replacement is the way to go ( around 250) plus labor and freon r22 e mail add aljpuig@yahoo.com.
Posted on May 06, 2010
Hitachi 46w500 went off tonight during storms, low voltage, wont turn back on
There might be a failure on the power supply or horizontal section of the TV even if you see some light inside the TV. Some of the voltages could be missing and that is why the TV fails to power up.
If you know how to use a multimeter, you could check all the fuses from your power supply.
Unplug your TV from the main AC line if you intend to do it yourself.
You will know how much you can do or it might safer to contact a tech.
Let me know if you need further assistance
Jun 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
My wd-60c9 60 in. dlp hdtv quit working after a thunder storm it was plugged into a powerstrip . The only this that wont work are the tv and direct tv receiver.
fried it, unfixable, get a new one. and start unplugging everything during storms. if you still want to watch tv while there is storm get a old crappy small tv to watch while you high priced one is in safe position(unplugged)
May 23, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
I have recently replaced the fan motor on my Briskair roof top A/C unit, should the squirrel cage draw air from inside the trailer and blow out rear of the unit, or have I installed this fan incorrectly?
Yes the air should be drawn from the trailer, over the cold coils and then
back into the trailer, whether rear or front.
The condenser coils should be self contained on top and blow
warm air outside the trailer
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 26, 2010 | Dometic Rooftop RV Air Conditioner
Dometic RM2662 won't light on gas
change ignitor or possible bad board
May 11, 2010 | Dometic RM2652 Refrigerator
Hi, my problem with tv emerson plasma 42 etv4206pdp it does not turn on, after rainy and lighting day. i check the main power area and cant find anything grong. i dont know what else to do. if you had a...
It might have been blown out by the lightening storm. that happened to two of my tvs that were plugged in during a lightening storm. they both, and two dvd players, would not work after, but the ones that were not plugged in were fine. You should unplug your major electronic equipment during a storm, unless you have a power surge plug/equipment.
Oct 04, 2009 | Emerson EWL3706 37 in. LCD Television
My behringer mixer phx2000 was took a lightning strike. the right speaker does not work. everything else seems ok
Should either unplug all electrical equipment during a storm or get a grounded filter to bleed off excess voltages from storms, power company fluctuation etc. Once the mixer electronics are fried you are SOL (**** Out of Luck) I'm afraid.
Sep 13, 2009 | Audio Players & Recorders
2001 Dodge Ram 2500, no running lights on trailer
The truck is protecting itself from the load impose by the trailer.. Chk the plug on the truck for wire gauge size. Turn any electrical loads off on the trailer, any and all. If fuse still blows then the fuse is either underated or the trailer has a dead short. In fact turn trail main power panel of. All lights work you say. So ck the inverter for defect byturning off the inverter on one of the trailers.
May 28, 2009 | 2008 Dodge Ram Pickup 1500
Amana wall ac unit
Try using your remote to turn it on. This is what worked for me. Hope it helps!
Sep 06, 2008 | Heating & Cooling
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
