Jvc av-56wp94 has sound but no picture
Has sound but no picture,plz help if you can
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Its a pretty good set, If no brightness on screen I suspect you will find either the three tubes are not firing up (lit) or it has no high voltage and there are not too many things a do it yourself person can do unless they have a volt meter and know how to check voltages and resistance.
This model does have a light box which means all the working part of the set less the speakers can be removed--called a box as it looks like one when removed.
Most of these have convergence problems which will either result in a dead set with blinking power light or a 3d picture.
It is possible it has a short in the sweep circuit but that also triggers shutdown and the power light blinking.
About the only simple (not real simple) thing might be the voltage for the filaments in the 3 tubes may be missing, If high voltage was present and those not lit it could cause your problem.
In addition the set like most is well protected, if no vertical or horizontal sweep is detected the set blanks (turns off) the 3 picture tubes to prevent them from instantly burning the mark into the face or screen of the tube.
What I am saying is there are several possible reasons all of which require some skill to find much less fix.
Either (unless we have a tech in the family) time for a shop or time to retire the set and go shopping.
Posted on Dec 12, 2012
5 Suggested Answers
  • 126 Answers
SOURCE: i have a jvc av-28wft1eks i can see the picture
well take the back off on the transformer should be two adj. pot screen control on top focus on bottom normally try to turn up screen control good luck
Posted on Apr 03, 2009
johnnydiode
  • 647 Answers
SOURCE: JVC AV-32220 TV WAS WORKING FINE....NOW NO PICTURE OR SOUND BY
Power supply capacitor is usually suspected.
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour. Be sure to vote/rate me if this helped Thanks!
Posted on Oct 17, 2009
  • 275 Answers
SOURCE: jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Posted on Dec 01, 2008
micromend
  • 748 Answers
SOURCE: AV-27BM5 relays click on but no picture,high voltage or sound
It's been my experience that symptoms that point to the power supply, generally are not the case. Schematics now days are tough to find unless you are an authorized servicer for that brand. There are a couple of generic dealers out there but they don't carry everything. Before you replace the power supply I would suggest you go though other boards first looking for bad solder connections and/or transistors and IC's that may be defective. A good DVM with an ohm's scale should suffice. If you still can't find anything, I would suggest taking it to a reputable repair person.
Posted on Feb 25, 2010
Makes a poping noise out of the speakers when i turn it on? can ya help plz thnks james
If you have no video and its making a popping noise its mostlikely shorted convergence circuits. Contact www.TvRepairKits.com and ask them to make you a kit for chirping sets.
May 16, 2009 | JVC AV-48WP30 48" Rear Projection...
Good picture but no sound at all.
Audio board died take it to a service center. if parts unavailable time to invest in a HDTV set since the HDTV transisition is June 12th and there may be a chance it will not have parts soon.
Apr 26, 2009 | JVC AV-48WP30 48" Rear Projection...
Jvc av-32wf36--have sound no picture
Nov 30, 2008 | JVC AV-27230 27" TV
JVC 48" AV-48P776
no se ve bien los colores jvc 48 776
Nov 02, 2008 | JVC AV-48P775 48" HDTV
JVC AV32260G COLOR TV
try resoldering vertical ic pins
Apr 19, 2008 | JVC AV-32260 32" TV
No sound on JVC AV-48P575 48 inch rear projection TV
Try going into the menu and find something called, "center channel input." If it is on, the sound will not work. Turn it off, and the sound should be restored.
Mar 23, 2008 | JVC AV-48P575 48" Rear Projection...
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
No sound, no picture just clicking
Horizontal output transistor is faulty .
replace it.
Gopal
Nov 30, 2007 | JVC AV-30W475 30" TV
HAVE PICTURE BUT NO SOUND
check for center channel option in menu, change option and test
May 21, 2007 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
