Question about Ricoh GelSprinter GX7000 Printer
Mis-feeds on the Ricoh GX7000 printer
It's not the paper actually misfeeding in the printer, but appears to be the print head causing the issue. The print head assembly tries to make a fast move on the rails and comes to a screeching halt before going back to what it previously was doing. It is akin to the print head either losing it's place from the encoder strip or over-taxing the CR (carriage return) system by over-voltage/over-current. The print head assembly rides with what appears to be two "oil-lite" type bushings on a smooth steel rail on the back side and a simple Teflon tab on the rail on the front side. I've cleaned the encoder strip on several of these printers and sometimes that is the culprit. More often than not, cleaning the encoder strip doesn't help. The print head still jams on the rails. I've cleaned and polished the back rail, cleaned the bushings and the surrounding areas, cleaned the encoder strip sensor at the back of the print head assembly and none of this shows improvement concerning the print head jamming. I don't have any new spare parts, but am more than willing to find some, to keep some of these workhorses alive a while longer. Some of these Ricoh 7000 printers have run over 200,000+ 8-1/2" x 11" sheets without this issue. Some run less then 30,000 and these jams appear. I don't know what the MTBF is for these printers, but it varies wildly in practice. Anyone have an idea for a solution for these print head jams, I'm more than willing to listen. You can also contact me directly at curtiswright at charter dot net. Thanks in advance!
SOURCE: Ricoh IS420 is not evenly scanning text pages - light side edges not do to obvious cleaning, what next?
Dear David, I bought a second hand IS420 on ebay, and bought a service manual at: www.electronicsrepair.net/scan.shtml See #86 You can buy it for $10. Good luck, Brad
Posted on Nov 13, 2006
gremlin11
  • 78 Answers
SOURCE: Paper Jam from the duplex into the Main Unit
Sorry dude, not my thing, great with epson, canon, hp, lexmark, brother but not ricoh
Posted on Dec 11, 2008
  • 15 Answers
SOURCE: Richo is200e scanner ADF thinks there is paper in
These scanners will collect alot of paper dust. You need to remove the ADF cover and using compress air and or a vaccum blow out the jam/original photosensor's, I believe there are 4 sensors. Power OFF then ON and try it..
Posted on Apr 16, 2010
brett207
  • 231 Answers
SOURCE: SEEKING TO PURCHASE NEW SPARE PARTS
These parts have been on ebay before, so do a quick searsh there,
or go to,
www.scannerparts.biz
Posted on May 11, 2010
Testimonial: "I'm impressed by your RAPID RESPONSE. WILL RECOMMEND TO FRIENDS AND ASSOCIATES. KIKIKNOWLES"
  • 903 Answers
SOURCE: Paper Jam
Open up the doors and blow some compressed air throughout the paper path (where the paper travels up). Make sure to blow air onto the sensors, because paper dust can coat them, causing false jams.
Does the paper get out of the tray at all? There is a feed roller that feeds the paper up into the machine; if you remove the paper tray you can see this roller -- it's big and gray and has grooves across it -- above where the paper sits toward the front of the printer. Blow air onto this roller as well, and if you have either D-ink or a rubber rejuvinator, clean the roller with a lint-free cloth.
Also make sure the paper is snug in the tray and not bent or crooked.
Posted on Jun 05, 2010
What is causing misfeeding?
Either the paper is slipping and not reaching the sensors at the right time. or a sensor flag is broken/missing/out/stuck and the device stops the paper thinking there's a jam. Clean all the paper feed rollers with a clean lint-free towel and water only. See if that will improve the grip of the rollers. If they appear shiny, replace the rollers. They are too worn out to continue working properly.
Feb 29, 2016 | Xerox Phaser 6360 Laser Printer
Ricoh c2050 continuous paper jams
Problem with the hot section, service call needed. -Carl
Mar 25, 2014 | Ricoh Office Equipment & Supplies
Grainy prints
If the print head is not located in the cartridge then you need to clean the print head as there can be stuck nozzles or debris attached to it that cause a messy print.
Jan 11, 2013 | Ricoh Corp Aficio GX7000 GelSprinter Print...
My hp deskjet 6980 seems to be feeding the paper fine but starts the actual printing about an inch or two farther down then it should so that I can't print any forms like checks because it is not...
Check the following:
  • The specific Printer driver for your OS has been installed (look at Printer properties)
  • The correct paper size has been selected and loaded from the correct feeder slot.
  • Application software (such as MS Office) has correct print margins (and more specifically the heading margin)
ps. Mis-alignment of the cartridge will not cause such massive errors but would normally result in a 'fuzzy' printout.
Hope it helps and good luck!
Sep 23, 2011 | Office Equipment & Supplies
I have a ricoh gx 7000 used for sublimation. Everytime I turn it on, I get a "paper misfeed" message. HELP!!
Dear .
Paper miss feed error indicates to :
1- Piece of paper inside duplexer unit check out from the back side..
2- magnetic strip (encoding tape on the top of linear steel bar) is dirty or it has some ink spots
use alcohol & cotton pass along the strip from the 2 side.
Note turn your machine off and un-plug the power
To clean behinde the head area you should first turn the machine on, when the head move to the left side unplug the power cable
I hope it may help
Yasir Risay
Aug 20, 2011 | Ricoh A3 Gel GX7000 InkJet Printer
Paper misfeeding on one side but printer keeps printing with no paper
Look for any foriegn objects or old torn paper from an earlier jam. Something is either obstructing or mis-guiding the paper. If nothing is found, use a can of compressed air to blow thr paper intake area out, then test print again.
If still not solved, use a cottom swan soaked in alcohol to scrub clean the rubber paper pickup roller. Over time it gets slick from paper dust and the paper will notget grabbed evenly, causing it to skew as it's pulled in.
Jul 26, 2011 | Lexmark X2470 All-In-One InkJet Printer
Ricoh Gx7000 inkjet A3 Printer - what does 'error 990' mean?
Error 990 indicates a dirty sensor, so either a maintenance unit is dirty or you have a clogged print head. You can read more about this error on Richo website where you can see in the images what you need to clean.
Feb 13, 2011 | Ricoh A3 Gel GX7000 InkJet Printer
I get the same message coming up "remove paper standard tray"
Sounds like it is misfeeding from the Default tray (just not getting the paper into the machine). try removing the paper from the default tray, and use another one. If it works, then the paper feed rollers are the likely cause.
Jul 20, 2009 | Ricoh Aficio AP3800C Laser Printer
RiCoh 1075 MisFeeding...
The problem you are having is that developer has fallen down into that area good luck once this has happened the box must be taken apart and blown out...  good luck
Apr 22, 2009 | Ricoh Aficio 450 Copier
Ricoh GelSprinter GX7000 Printer Logo
42 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
