GE Profile Washing Machine gurshing out water
Water leaking from bottom of washer on the bottom left corner about 80% of my loads. Large accumulation of water.
    Problem Solver:
  • 14 Answers
Open the door and stretch the rubber seal to see if it is split.
It is possible that one of the two hoses feeding the pump have splits in them, only way is to turn power off at wall and with a couple of pints of water in lift machine at an angle prop it with solid objects i.e. wood and squash hoses with your hands MAKE SURE POWER IS OFF AT WALL Tim
Posted on Jan 13, 2009
How to take the back off GE Profile washing machine
take off the bottom on the front, then pull the drum. cant take the back off.
Oct 08, 2012 | GE Profile WPRE6150K Top Load Washer
Washing machine leaks at bottom left corner. Water still machine after drain/spin cycyle
My GE washing machine leaks while filling up in the first cycle in the left back corner. Need help!
Jun 16, 2010 | GE Profile WPRE6100G Top Load Washer
My GE Washing machine appears to be leaking from the bottom
It sounds to me , you need the seal and bearing kit.. It is over 300.00 dollar repair, if it is an old washer I would say go get a new one
Jan 13, 2010 | GE Profile Performance WPSF4170WAA
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Top load washer.
Hello rschneeweis
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
GE Top-loader Leaks Water from Vertical Tube Behind Tub on X-Large Loads
it sounds like the basket is not locked when it is agitating, if so the water will climb the wall during the wash cycle and leak out of the overflow (which is the plastic tube you described). if this is the case, it is a transmission brake problem. it can be fixed by a professional, but you might want to look into buying a new machine.
Jun 18, 2008 | GE WHRE5260E Top Load Washer
Water leaking when when washer is running a large or super load
the leak could be coming from anywhere in the washer it just leaks out from the lowest point of the washer i would suggest placing a putty knife under the top on the right and left side and pushing the tabs in to pop off the front panel to see where the leak is coming from
Oct 30, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
