Question about Sewing Machines
I have a Brother Auto Tension XL-3000 -The upper check spring is bent out of shape. Does anyone know where I can get one of these parts....??
  • Sewing Machines Master
  • 7,365 Answers
Here is the names of 2 sites call them or email them about the
part you need
sewvacdoctor.com
a1sewingmachines.com
Posted on Dec 12, 2012
SOURCE: broken horizontal spool spin Brother Xl 2027
hi i have the same machine listed on ebay works great just the foot need to be replaced hope that helps
Posted on Jun 24, 2008
SOURCE: My brother sewing machine is new and I've checked
Yes. Open the bobbin and u will see a screw pressing down a metal sheet, which is actually a spring.
This is meant for adjusting the top tension. Loosen this screw by quarter or half a turn and see if it is giving the desired result. You may have to try a few settings before you arrive at the even top and bottom tensions when your thread tension adjustment scale is midway position.
Please note that you adjust the thread tension on the machine to adjust the bottom tension(not the top) .
Please let me know if this solved the problem.
Posted on Oct 17, 2009
redbeard00
  • 957 Answers
SOURCE: Thread tension for Brother XL 2230.
If you have pattern dials set correctly then I might guess that one or more sets may have been missed when the thread was being set up in the machine. most of these models show either arrows or numbers for each or way the thread needs to be routed.
Posted on Apr 26, 2009
  • 1116 Answers
SOURCE: The upper thread tension on my Bernina 930 is too loose
If you threaded the machine with the presser foot lever raised and the stitching is still loose, the tension control may need a new spring or the entire control may need to be replaced.
Berninas tend to be the only brand that hold their value and it would be worth the expense to take it to an authorized Bernina dealer for service and repair.
Posted on Mar 25, 2010
  • 23 Answers
SOURCE: How do I adjust the tension on my brother xl-2620
Rotate the tension dial (which is the dial furthest to the left) right or left to adjust the tension.
Posted on Apr 13, 2010
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
3500 XL. Why can't I get upper tension set correctly?
Hi
you bobbin case has a screw.
a small flat head screw
tighten it slightly this should help
the screw is also a tension adjustment
Jul 12, 2015 | Brother Sewing Machines
Brother XL-2600i upper tension too tight even when set to ZERO
I agree with you to take it back & buy another brand
Sep 30, 2012 | Brother XL-2600
I need several parts for my brother CS8150
sewingpartsonline.com
sew4less.com
sewvacdoctor.com
ebay
Apr 19, 2012 | Brother CS-8150 Computerized Sewing...
Does anyone know how to set a Brother sewing machine for a straight low tension stitch?
Stitch length on 2.5 and stitch width on zero, and just loosen the top tension by a half number if you want the tension looser. If your machine has a stitch selector knob, make sure it is set to the straight stitch setting.
Oct 10, 2011 | Brother XL-2600I
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
Good day!
Jun 07, 2011 | Brother CS-6000
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
Tension problems
Possibly you have the bobbin in upside down and its turning the wrong way. Read manual. If you have done everything the manual says then it must be a mechanical issue such as the small thread take up spring or maybe the tensioner discs are dirty. Timing slightly off or there is a burr on the hook that catches the thread. Have a tech look at it.
Feb 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
55 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
