Question about RCA R52WH73 Projection Television
Why is my 1998 volvo s70 leaking oil - RCA R52WH73 Projection Television
    Top Expert:
  • RCA Master
  • 14,553 Answers
Somehow this got posted in the TV area here, Look to see where the leak is coming from and better yet have a mechanic take a look, oil leaks can either be a minor repair or a major repair depending on where it is coming from.
Posted on Dec 15, 2012
Both radiator hoses are hard why 98 s70 volvo turbo
It has been my experience that both radiator hoses get hard with age, check the hoses for age and cracking because they usually are hard right before they give out. They get hard when they get old due to excessive oil covering because of an oil leak and heat from the engine and the coolant within the hose.
Jul 10, 2014 | 1998 Volvo S70
How do i fix evap control system on 1998 volvo s70
Check for vacuum leaks. I will bet that you have a bad or leaking vacuum hose between the intake manifold or PCV System and the Evap. System.
Nov 19, 2012 | 1998 Volvo S70
Triangle light on 1998 s70 volvo
sounds like a coil issue
Sep 03, 2012 | 1998 Volvo S70
My 1998 volvo s70 overheated today. the oil was fine and so was the antifreeze. no leaks underneath either
If the anti freeze level is fine and there is no apparent leaks of any kind there is a good chance that your thermostat is stuck shut and needs to be replaced. The good news for you is that is a fairly cheap and fast fix. I hope this helps you out, and good luck.
Aug 28, 2011 | 1998 Volvo S70
My volvo s70 1998 transmission oil coolant was leaking and fixed. I flash the transmissio oil and changed the oil. After this process the car does not move in all gears either forward nor reverse.
Depending on how long it had been since servicing all of the old fluid might have been what was sealing it up and th neww fluid might be too clean to operate without some major work .
Sep 14, 2010 | 1998 Volvo S70
WINDOW WASHER CONTAINER CRACKED & LEAKING - VOLVO S70
not that hard. you need to remove the wheel arch and its right in front of you
Dec 02, 2009 | 1998 Volvo S70
The Ever-Elusive Volvo Radio Code...
If the dealer performed the work I would be VERY persistant in them getting your radio fixed. Talk to the Service Director.
Aug 13, 2009 | 1998 Volvo S70
Chain smoker
Turbo oil seal is probably bad. This lets oil leak into the air intake from the turbo bearing. If smoke goes away during hard acceration, then this is probably your problem. Turbo replacement or rebuild is the fix for this.
Mar 20, 2009 | 1998 Volvo S70
1998 volvo s70 heater smells strange and smoke fills the cabin
Your heater core is leaking. The smell and smoke is from the coolant evaporation.
Oct 17, 2008 | 1998 Volvo S70
Distributor leaking oil
ok if the oil is coming out of the distributor it has to be taken right out and marked to go back in the correct spot there is a rubber o ring on the shaft of it.
Sep 04, 2008 | 1998 Volvo S70
RCA R52WH73 Projection Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
