Question about Toshiba Satellite A505D-S6008 (4400 mAh)
Common Issues With Toshiba Satellite A505D-S6008
USB ports
  • Toshiba Master
  • 27,725 Answers
W7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply Hope it helps.
Posted on Dec 12, 2012
Laptop fan needs cleaning
contact authorised toshiba service center
Oct 10, 2013 | Toshiba Satellite A505D-S6958 (4400 mAh)
USB ports not working
jst see control panel usb setting or ur power scheme setings
Mar 23, 2012 | Toshiba Satellite A505 Notebook
1 usb port on toshiba satellite c660 doesn't recognize mouse
If is just a USB port, then it could be a driver problem, or that USB hub is turn off, or is a fried/bad USB port. Try another USB device on that port too.
Mar 19, 2012 | Gigabyte GA-8I845GVM-RZ Motherboard
I forget my bios password for (a505d-s6968) and i want the solve for this problem
Toshiba Satellite A505D-S6968 Laptop
Make a device that you connect to your parallell port,
a lot of Toshiba computers remove the password when you boot it up.
The device, named "loopback" ,could be made out of any parallell wire with 25pins connectors (db25).
Connect these pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, 18-25.
// Eman E-man: http://www.hardwareanalysis.com/content/visitor/42617/
Aug 18, 2010 | Computers & Internet
How to Tweek a Toshiba satellite A505D S6968 notebook to save battery power to last longer before recharging
Only way is through the power settings in the control panel.
A few handy tricks are:
disable the wireless antenna when you are not using it (the device uses power while it continuously scans for networks)
dim the monitor as much as you can
remove cd's from the drive when you are not using it,
remove any SD cards or USB thumb drives when not in use
Hope this helps. Aside from all of this I recommend picking up a backup battery that can be swaped when your current one goes dead. In essence it doubles your use time.
Sep 27, 2009 | Toshiba Computers & Internet
My usb ports dont work in my toshiba satellite A135-S2386
Unplug the PCMCIA card first.
Then disable the onboard USB hub and ports. Shutdown, plug in the PCMCIA card and reboot into Windows.
Let Windows detect the card and if necessary put in the driver CD for the card. Had similar issues with my desktop PCI USB card.
After disabling the Onboard though it works perfectly fine now.
Hope this might help you a lot.
Please rate me if i a m helpful.
Thank you.
Beboy
Aug 18, 2009 | Toshiba Satellite A135-S2386 Notebook
My usb flashdrive is not recognized on any of my usb ports on my Toshiba satellite m35x-s163, can you help?
Test usb port with another device,
check in my computer for the drive,
Test usb flash in another Pc,
Manufacturers website for a possible driver.
if still not working then it's faulty,
Regards
Rpf
Apr 14, 2009 | Toshiba Satellite M35X-S163 Notebook
Toshiba Satellite A505D-S6008 (4400 mAh) Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
