Question about Irons
Standby light flashes and therefore no steam on my hin172 steam generator iron
No generator pump noise and standby light flashes constantly
  • 833 Answers
SOURCE: Tefal Pro Express Steam Generator Iron
Irons are generally not worth repairing. That said, try to clean out any mineral deposits with a mixture of 1/3 vinegar and 2/3 water. Put in the usual amount. Warm the iron, try to get steam. Empty the iron and do it twice more. Then, rinse it out with plain water.
You may get lucky!
Posted on Jan 23, 2008
geokohler
  • 304 Answers
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
SOURCE: Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Posted on Sep 20, 2008
SOURCE: have just bought kenwood steam generator iron but
Press the variable steam control and the power on/off button to stop the light flashing - that worked for mine!
Posted on Sep 30, 2009
SOURCE: I have a Swan S15040 steam generator iron, the
I had same issue , now , once you turn the unit on , you should see displayed 3 steam jets and the flashing standby , turn the dial on the iron to max ,press the steam button on the machine to max steam , leave for a minute or so , now press the steam button on the iron , does it make a noise ? if it does , slightly raise the whole front end of the unit ( easier if you have the iron on the worktop and not on the unit !) for a minute then try and press the steam button on the iron again . I think there is a bit of an issue about the conection between the water tank and the filter . This solved my issues and i do hope it will help you .
Posted on Oct 16, 2009
The iron will not steam and the standby button is constantly flashing
Always switch off the unit and allow to cool before cleaning or storing. .... If your steam generator does not work, check the following points: ... working temperature, the LOW STEAM ICON will flash whilst the heating cycle takes place ... steam. 9 When ironing is complete, press the POWER. STANDBY button.
Jul 27, 2011 | Morphy Richards Jet Stream 42271 Iron
Hi iv got a hinari steam generator iron hin001 that comes on and heats up but no steam comes out when you press the button and theres a standby sign flashes on the display can you help me please
don't spend your money on a calc cartrage it will not get it out of standby.
the controll unit carnt tell if it needs replaceing!
if the standby light is flashing it means it carnt heat the steam tank. if the iron is not heating as well it is a buggerd control pcb!
if you live near Newcastle I could fix it for 20 pounds
Paul@rochy.com
Feb 03, 2011 | Maytag MLI7500A Iron
I have a Swan S15040 steam generator iron, the stand by light is permanently flashing, no matter what temperature setting i put the iron on. No steam is generated. I have tried holding the steam button...
Jul 18, 2009 | Black & Decker Steam Generator SG200 Iron
It gets hot but there is no steam or noise from it also the red standby button is flashing
i have a tesco steam generator iron, model no. sgc2 it has no steam or noise but red stand by light is flashing
Jul 11, 2009 | Irons
Hi i have an edbs920 steam generator iron, my problem is that it will dry iron but wont steam up anymore, after turning the system on the power indicator light should turn from the flashing orange pre...
it can be that one of the thermostats controlling the water flow pump into the steam generator has become open circuit, caution is advised as this can potentially overheat the steam generator for there being lack of water, depending on your system design...i could be wrong just a guess !
Apr 30, 2008 | Euro-Pro Steam Generator EP8001 Iron
Irons Logo
60 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
