Question about Mitsubishi WD-60737 60 in. HDTV
Picture on my mitsubishi wd 60737 is dark. i have increased the brightness but picture looks like a night time scene
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
A few things occur to me, if Lamp not recently replaced (2year average life) it may be nearing the end of its life.
Just a few models (not sure if this is one) use two mirrors where most just have one large mirror.
If the issue was gradual you may have the two mirror set, one tiny mirror at bottom of screen area points up and reflects the image into the large mirror in the back of the set which puts it on the screen to view.
If your model has the two mirrors the little one will be coated with dust and such and cuts brightness up to 70%
You can call Mitsubishi and ask if your model has two mirrors or one, if Two mirrors and they will not tell you how to get at them I can.
Let me know if you need more help.
Posted on Dec 12, 2012
Testimonial: "AWESOME and im calling Mitsubshi right now. Thanks for you assistance. "
welcomejee
  • 10594 Answers
SOURCE: Mitsubishi DLP - WD-60737 -
This tv has self diagnostic feature that will show last error through front light blinks, there is procedure to activate and read out error code to diagnose problem section of tv to solve its issue so to get tv back in business.
Let me know to proceed.
Thanks.
Posted on Mar 03, 2011
  • 556 Answers
SOURCE: Our Mitsubishi DLP WD-60737 is only one month old.
Call Mitsubishi and find out who is the closest warranty repair service station in your area, they will take care of this for you.
Posted on Sep 04, 2009
  • 541 Answers
SOURCE: Mitsubishi WD-60737 will shut off on its own while
These units had problems with capacitors in the power supply and main boards. Unless you like really hard CHINESE PUZZLES you are best to leave this to a pro.
Posted on Oct 13, 2009
  • 4234 Answers
SOURCE: no sound on my mitsubishi wd 60737 fresh out of
Verify that the speakers are enabled. This should be a menu option. If they are enabled and you still get no sound, there is a problem inside the set. You indicate that this is a new set. Return it for a warranty exchange. DO NOT open up the set as that will void the warranty.
Dan
Posted on Dec 01, 2009
  • 8457 Answers
SOURCE: My mitsubishi Model # WD-60737.
Tv under a year old call Misubishi for a warrenty repair.Flashes staus light mean could be any these parts have problems power supply board,Ballast board or the pojection lamp itself.
Posted on Jan 11, 2011
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Jvc 61g787aa picture too dark on night scenes
Did you try going into the menu and increasing the picture brightness?
Jan 30, 2014 | JVC Televison & Video
What is the picture settings for wd-73834 mitsubishi hdtv
Most of this is personal preference---if contrast (picture) is set too high the picture will have some smearing on dark or even very bright scenes--try to have that set at about 70% and brightness just a bit higher---a proper setting of the two will give a better picture with more clarity. Color and tint to preference and sharp to not full smooth (mid-range)
Other than these signal provided accounts for clarity--pixels stopping etc is not the set but the signal provided not fast enough to keep up----cable and sat often jams a lot of info into a small space and that sort of issue results.
If you have a HD quality Blue Ray compare it to your signal source and usually it will look much better.
I have taken the time to cover as many bases here as possible.
Hope it helps in some small way.
SD TECH
Aug 27, 2012 | Mitsubishi WD-73734 73" Television
Mitsubishi wd 60737 screen going dark
Kindly adjust brightness/contrast/sharpness settings. If there is no improvement, this might require attention by a qualified service technician.
Jul 12, 2012 | Mitsubishi WD-60737 60 in. HDTV
I have a Mitsubishi DLP WD-57831 and the dark colors are hazy/milky on the screen, and the lighter colors look normal. There's a 'ghosting' effect which makes it difficult to watch night time/dark scenes. ...
This tv require projection colors lens R,G,B clean and it coolant chemical replacement.Should check for it prices by a tv shop or shops for best prices for it services.
Feb 01, 2011 | Mitsubishi WD57831 Television
Mitsubishi WD-62527. Dark picture.
That unit is a two mirror set. Meaning the light engine lens shines down onto a small mirror and that is reflected onto a large mirror and then onto the screen. Gravity being what it is dust and other contaminants cover the lower mirror. Moving the set would only aggrevate dust settling on it. To fix the problem the screen must be removed and the mirror cleaned. You won't believe the difference. It will be like watching a new tv.
May 28, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Brightness difficulty
I had the same problem and so went into the menu and selected brightness and increased the number, and my dark pictures were much better.
Jan 26, 2009 | Protron PLTV-4250 42 in. LCD Television
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
Mitsubishi WD-60737 60 in. HDTV Logo
367 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
