Question about HP LaserJet 3055 All-In-One Printer
Language setting On my HP Laser Jet 3300 i accidentally hit the language setting and change my display settings to russian. i can not read russian so am not able to get back to english. can you help me. thank you
  • 1 more comment
  • Anonymous Mar 27, 2014
    how to change language to english
    need to change back to english from russian
    need to change language back to english from russian
    Scholar:
  • 77 Answers
Try this: 1. unplug all cables from back of unit (turn power off as well) 2. while the printer is off hold down the * and 5 3. while holding them turn printer on 4. continue to hold buttons until display reads 'Permanent Storage Init' 5. then release buttons 6. at the end of reset it will ask you to select language and location, just press enter then 1 to confirm Hope that works!! Ed PS. You could have picked an easier language!!!
Posted on Jun 12, 2007
Change to russian language on nokia c2-01
Follow these steps to change your language to English: 1. Go to menu on your phone. 2. then move to settings. 3. Under settings you will see language settings. 4. pick the language you want under language settings. You are back to English. I hope that helps. Good luck.
Read more: How do I change to russian language on my Nokia c 2-01? - My Nokia C2-01 is in English. I want to change it to Russian Language. It is not listed under settings. How do I do it? :: Ask Me Fast at
Mar 02, 2013 | Nokia C201 Cell Phone
Hi..,please i want to change the language from chinese to english language for hp laser jet 5200
You will find to set the language in this manual:
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00575070/c00575070.pdf
There is also the possibility to change the settings via Web Server. You will find in the same manual how to use the Web server.
Jul 18, 2011 | HP LaserJet 5200 Printer
How to change the display langauge on an HP colour laser jet CP2025 currently in russian
1. Press OK to open the menus. 2. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the listings. 3. Find the System Setup menu and press OK. First option should be language.
To translate what shows up on the lcd screen on the printer, try using http://translate.google.com to translate it to English so you can proceed.
Jun 30, 2011 | HP Laserjet Cp2025n Printer
How to change the display language on a HP Colour Laser Jet CP2025 currently in russian
Unplug all cables and cords after turning off the HP CP2025. Hold down the "OK" and the small left-directed return arrow button. While holding them down, reconnect the power cord and turn the machine on. The screen will display "Permanent Storage Init." Release the two buttons. It will then ask you what language you want. Follow the prompts. Thanks to Edward Paulinski and his instructions for the HP 3300. I was able to convert his instructions to work on this model!
Dec 03, 2010 | HP Laserjet Cp2025n Printer
Changing the language display on xerox n40 printer
IF YOU CANNOT READ RUSSIAN, THEN MAY I SUGGEST ADD AND REMOVE, DELETE SOFTWARE FOR THIS PRINTER AND THEN REINSTALLING THE SOFTWARE, IT SHOULD THEN ASK YOU WHAT LANGUAGE YOU REQUIRE.
Jun 16, 2009 | Xerox DocuPrint N40 Laser Printer
How do I change my HP 2600n Language back to English
A. To change the display language back to English, please perform the following steps:
1. Press the right arrow 2 times, press the OK button (you should be in the System Setup menu).
2. Press the OK button again (you should be in Language).
3. Press the right arrow until you see something that may be English, press OK button. The menu is a continuous loop, so if you miss it the first time the option will return.
May 22, 2009 | HP Color LaserJet 2600n Printer
A student has reset the menu to Russian.
My company uses nothing but HP printers some are connected to the network while others are locally connected to a computer. I have worked with this exact model.
First, the easiest thing to try is to power cycle the printer. Hold down the button to turn off then turn back on. You can also unplug it from its power source then plug back in.
Power cycling this printer should reset the language to default (English) or it will let you select the language when it comes back on. If that doesn't work then you can try to change it using the installed software.
Considering the fact that someone accidentally changed the language, I am assuming this printer is connected directly to a computer that you all have access to and this is not a network printer.
If this is a local printer (connected directly to the computer via USB or parrallel port) then you should have an HP Toolbox app or some other program that allows you to configure software related settings for the device. Open this tool and you should find an option for the language. This may not be available, depending on how the installation was handled (if it was installed using the CD provided by the manufacturer or installed using downloaded drivers).
Try this out and let me know if it helps.
Mar 26, 2009 | HP Color LaserJet 2600n Printer
HP Laserjet 3030 printer/scanner/fax Language has
How can i change HP laser jet 3030 printer's language?
Mar 17, 2008 | HP LaserJet 3030 All-In-One Printer
How to change the language
Go to the Réglages option, then to Langue and select English.
Oct 09, 2007 | SanDisk Sansa c200 MP3 Player
HP LaserJet 3055 All-In-One Printer Logo
438 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
