Question about Numatic GVE370 Canister Wet/Dry Vacuum
Spray pump stoped working & making buzzing noise
Spray pump stopped working & its now making a buzzing noise
The Rug Doctor stopped spraying.
did you run out of water ???
Sep 30, 2015 | Vacuums
My rug doctor will not spray out water
check your spray jets are not blocked but also check your small pump is working & operating that spray the water out of the nozzles
Sep 01, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
George pump strange noise
Check for blockages in all the filters and hoses, from your description it sounds like the pump is trying to go but can't
Jun 20, 2014 | Numatic GVE370 Canister Wet/Dry Vacuum
My Dyson D17 Animal vac makes a buzzing noise when the belt turns. I took the belt off and turned the small metal gear that turns the belt. That is what is making the slight noise. My wife vacuumed the...
Try not to **** up any more water. Don't use until you can dry it out well. Hopefully you live in a warm climate so that will happen sooner than later.
Sep 23, 2013 | Vacuums
My vax rapide xl ultimate v-027y brushes not working..new belt fitted and same problem
hello i have a vax rarid xl carpet cleaner when you switch power on just makes a buzzing noise can you help thanks
Jul 15, 2012 | VAX Appliances Vacuums
My eureka atlantis 2590 deep steam extractor will not spray
is the spray pump making a noise? if so, clean spray jets with a lime/calcium remover like "clr."
If the pump isn't making noise, try the rest fuse button.
If that's not it, your pump motor or solenoid is toast.
Sep 28, 2010 | Eureka Atlantis 2590A Wet/Dry Vacuum
The unit stops sraying out liquid after one pump
this has o rings and do need to be replace is the suction is lost
Mar 23, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
My bissell proheat 12 amp will not spray water on to the carpet,nor will the hand tools spray water?
The water is pumped via the belt that drives the pump. Remove the belt pump on the left side of the unit using a screwdriver and prying upward in the slot in the rear of the belt cover. The belt cover has holes in it. Check to make sure the belt is not broken. If it is replace, about $3-4.
Good Luck
Feb 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
Numatic GVE370 Canister Wet/Dry Vacuum Logo
71 people viewed this question
Top Numatic Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
