Question about Whirlpool Dryers
What size breaker is reommended for electric dryer 220V?
Electric dryer 220V trips the break every once in awhile but not every time. Might use it 4 or 5 times before it trips the breaker.
  • 1,543 Answers
Electric dryer uses a double pole 30 Amp breaker. Check for a loose electrical connection. Check that the screws holding the wires on the breaker itself are tight. Next, check the screws for the ground / neutral in the breaker box. Next, check all the connections in the dryer recepticle (where the dryer cord plugs into the wall) Finally, check the connections where the cord connects onto the dryer. If all connections listed were good tight connections, replace breaker.
Posted on Jan 14, 2009
No power to the display, dryer will not turn on
First thing you need to do is check the Circuit Breaker for the dryer. If it is tripped unplug the dryer and reset the Circuit Breaker. Now plug in the dryer and try to run it. If it does not work again check the Circuit Breaker again if it is tripped again unplug dryer and call someone that can help you or fix it. If the Circuit Breaker is not tripped check for good power readings on both power lines coming into the dryer. Should have 110V or more on each line to neutral, and 220V or more between each line. If you do not have the correct voltage at each line check Circuit Breaker for good power coming out.
Mar 13, 2014 | Maytag MDE9700AYW Neptune 174 Electric...
I have a Kenmore Elite 4 electric dryer. I know the the electricity is working because the light is on in dryer. However, I cannot turn on my dryer. The
The dryer runs on 220V. You may have one of the two breakers tripped. Check to make sure both breakers are engaged.
Apr 25, 2012 | Dryers
MY MAYTAG MDE9700AYW WILL NOT TURN ON
Are you getting power at the console? Also, check to see if one of the breakers has not tripped. Dryer runs on 220v and you may have tripped one breaker that will show power to the unit but won't let it start.
Dec 24, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer keeps tripping the breaker
need more info does it run for awhile before breaker trips
Jun 01, 2010 | Whirlpool LER5636P Electric Dryer
Have a dedicater 220v 20a circut break to a clothes dryer. The only work done but the electrician was a new main grounding wire and removed conduit and wiring in the basement. Now the breaker opens after 1...
Typically, a standard electric dryer is 30A 240V unless it is natural gas. If the wire is #10awg then you can put a 30A circuit breaker on it. If the wire is #12awg then you DO NOT want to put a larger circuit breaker on it or it over heat the wiring in the wall. If it was a short in the wiring the circuit breaker would trip immediately even with out the dryer plugged in. If it was a grounding problem the circuit breaker would not trip at all, it would just electrify the dryer chasis. It sounds like it is an over current problem, drawing more than 20 amps through the circuit breaker, or like the dryer has an internal problem that is causing the circuit breaker to trip.
Nov 21, 2009 | Gb Electrical 100 Amp GE Load Center
Whirlpool model no LEB6200KQ0 will only dry on the Very Dry Cycle. I have to run on the timer dry 3 to 4 times to get the clothes dry.
Judging from the model number, this is an electric dryer. There can be several things wrong with it. I would start with the vent. Make sure it is not clogged (especially at the end) or kinked behind the dryer. Also, check your breaker. Electric dryers can run with one half of the 220v breaker tripped. Try switching the breaker to the off position and then back on. That may solve your problem, but if it returns, you will need a qualified electrician or appliance service tech to see where the problem is originating. If neither of these help, you will need a tech to see whats going on inside the dryer. hope this helps
Nov 09, 2009 | Whirlpool LEB6200 Electric Dryer
MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Feb 27, 2009 | Maytag PYE2300AY Electric Dryer
The dryer acts as if no electricity is going to it. It shut off
Is this an electric or gas dryer? If electric, it would be wired seperately from the washer (220V vs 110V) and if so, maybe you tripped a circuit breaker or blew a fuse - that would be the first thing I would check. If you find nothing wrong there, I believe most dryers have an internal overload circuit and if you are not handy, an appliance repairman, or an electrician, I would suggest calling an expert.
If you did trip a circuit breaker and reset it, and it trips again.....better call for service.
Dec 10, 2008 | Whirlpool GEW9250 Electric Dryer
Problem with my GE dryer
  • turn your circuit breaker off then back on. sometimes the only one side of the dual 220v breaker will trip leaving you with a non functioning machine thats seems to have electricity going to it.
  • another thing to check is the door switch.
Jul 06, 2008 | GE DCSR483EA Electric Dryer
Hooking an electrical dryer to a breaker
You will typically need a 40 amp 220V circuit for this ( check with local building inspectors).  You will need to run some hefty wire probably #8 three wire  (again check) and install the type of plug receptacle that is on the  dryer cord.
Inside the breaker box you will need a dual breaker 220V breaker rated at 40 amps.  The wire coming into the breaker box will need to be clamped in place with appropriately sized wire cable clamp where the enter the box through a knockout- available at any hardware store.
Now the big question-  why are you switching to electrical?  Gas is pretty much half as expensive as electricy  and will dry the clothes faster (usually gas dryers generate more heat than electrical ones).   Just wondering..
Oct 20, 2007 | Dryers
Dryers Logo
128 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
