Question about Ravelli APGL4 New Professional Tripod with Adjustable Pistol Grip
Ravelli Ballhead Tripod APGL4 quick release issue
The Latch and screw for the switch/latch release button on the quick release tripod came off and now I can't figure out how to re-attach the button so now my Camera is stuck mounted on the quick release handle. There seems to be a spring inside of the device but can't figure out how to re-attach to release the camera? Please HELP!
Hello, I have this same problem and I am at my wits end, can't figure out how to get this thing off! Have you figured it out as of yet!?!?!
Posted on Apr 23, 2013
  • Synics Apr 23, 2013
  • Synics Apr 26, 2014
    Btw, I eventually figured it out later that night. You have to pull the spring out and this piece will fall out, enabling you to put it back together. Pick up a longer screw at lowes or home depot, and your good to go.
The nut which holds the quick release latch which is spring-loaded on the top of my Maxell tripod fell off and I can't seem to put all the part back together so it works correctly.
You could give us a call at Spartan Photo Center, we might be able to guide you through putting it back together. You could also ship it in to us and we could put it back together for you. You can contact us at 864-583-6835
Feb 18, 2013 | Camera Maxell Tripod With Bubble Level 20"...
Need to replace the ravelli quick release plate for ballhead tripod
Here is the complete unit replacement:
http://www.amazon.com/Ravelli-Professional-65-inch-Carbon-Release/dp/B004RCHX0W
No parts lists are available on line for this tripod.
Jan 14, 2013 | Ravelli Professional 65" Ball Head Camera...
DONT KNOW HOW CAMERA GOES ON TRIPOD WILL ANY CAMERA WORK ON IT OR DOES JUST CERTAIN ONES WORK ON IT IT IS A DYNEX 60 " DIGITAL TRIPOD
It is usually obvious where the camera goes, so I am pretty sure that what you have is a tripod with a quick release plate that doesn't have the quick release plate fitted. This is very common when you buy a tripod second-hand. The quick release plates get attached to a camera and people forget to reunite them with the tripod before disposing of it.
If you bought the tripod new, then look in the packaging for a plate with a screw to attach to the normal camera tripod screw in socket. There ought to be more than one. The screw is standard throughout the world, except maybe Germany that used to use a different size. Any camera you have will have this socket on the bottom, a threaded hole about a quarter inch (5 or 6mm) in diameter. The plate will be a design peculiar to this make of tripod, and if you lose it or don't have it you will be unlikely to get another.
Jan 25, 2011 | Dynex 60" Universal Tripod
How to put a camera on it
If it's a quick release tripod you need to remove the quick release plate (Usually a release lever to the side of the top of the tripod) and then fasten the plate securely to the camera and then the plate to the tripod. Older non-quick-release tripods have a knurled screw located below the flat area where the camera is attached. If the screw is missing, get a relacement from your local hardware store - 1/4" -20. (Find a way to keep the new one from getting lost.)
Jun 12, 2010 | Ambico 67" TRIPOD
I have a SLIK Single Action Panhead Tripod. How do I mount the camera on the tripod?
it is a quick release plate. there is usually a button or lever to release the plate. you then screw the plate into the bottom of your camera or camcorder and mount the plate back onto the tripod. you can leave the plate on your camera when you store it to allow for faster setup.
Jun 03, 2010 | Slik AF-1100E Trigger Release Ball Head...
Screwing camera onto tripod quick release
Usually the camcorder has a hole next to the mounting screwhole. The plastic nub fit into the unthreaded hole, the mounting screw screws into the threaded hole. The nub is to help prevent the camcorder from rotating while you are using it on the tripod.
Feb 08, 2009 | Sakar TR-60 Tripod
Focal tripod
I have a Focal tripod model # 20-08-87 that is missing the quick release plate. I cannot seem to locate a replacement. Can you help me locate one??? Thanks, Jackie
Mar 01, 2008 | Sanford Traveler Tripod
Solidex camcorder tripods
OKAY!! Thanks to the reply of "Baldwink", I was able to locate the product he suggested here in the U.S. from several dealers. This is the plate that mounts to the camera and allows easy removal/attachment to the tripod.
For the Solidex VT-90 tripod (the one I have and may fit others), order the Cullman CU-40470 Quick Release Plate. This is also described as the "Cullman Medium Quick Release 42mm" plate.
If you don't have the VT-90, measure the shoe plate area on top and remember that there will be at least one beveled (angled) area. Mine measured exactly 42mm square, so I am confident that the Cullman plate will fit. Also, the standard thread size for camera mounting is 1/4", but there are some cameras that use 3/8", so you might want to double check your camera for this spec.
I googled "cullman 40470 quick release" and found several U.S. dealers. The best price was from Adorama.com at $14 plus $5 ground shipping. Some dealers want as much as $33.
After nearly 20 years, I can use my Solidex VT-90 again!
Nov 15, 2007 | Photography
Slik U 200 Tripod
17 th street Photo
Oct 27, 2007 | Slik U-212DX Tripod
Ravelli APGL4 New Professional Tripod with Adjustable Pistol Grip Logo
267 people viewed this question
Top Ravelli Photography Experts
Tony
Are you a Ravelli Photography Expert? Answer questions, earn points and help others
