Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
I have a Cozy Gas Room Heater year 1991 60,000 BTU, smell gas
There is a wire coming from the valve unit which attaches to a metal pen looking thing. This broke off at the valve unit and I smell gas. Can this be fixed? What is this metal wire with pen on the end? I have searched the Internet and can't find it anywhere. Any help would be appreciated.
thank you, Deb
  • inlitetenme Jan 14, 2009
    no, I know what the thermocouple is. This wire is much smaller in size. It's connected from valve unit and then just attaches to the back of the heater, clips on. Could be some kind of a ground?
    Thank you though.
    Problem Solver:
  • 10 Answers
That is the temperature sensor probe. You will need a new control valve.
Posted on Feb 03, 2009
  • Cozy Master
  • 3,160 Answers
Do you mean the thermocouple ? look on google thermocouple picture and see if that is it ?
Posted on Jan 14, 2009
  • Paul Carew Jan 17, 2009
    yes it could be the ground wire
I have a Cozy gas heater is there any way of changing the mechanical nob thermostat to a regular wall mount one
need to change the gas valve and add a pilot generator and stat wire and a wall stat. If your unit is natural gas part numbers are gas valve 84085// pilot gen. 70098.
Nov 07, 2010 | Cozy (W352E) Heater
Cozy heater will not fire, replaced powerpile but gas valve will not open Jumped tstat also
pull stat wires off of valve and put a jumper wire across the 2 TH terminals on the valve, if it comes on could be the stat wire run a peice of stat wire from unit to stat to test.
Oct 22, 2010 | Cozy (W352E) Heater
Gas explosions coming out of Cozy wall heater
It could be one of two things. Either you have a weak gas valve or dirty burners. Either way you will need to get a technician out to check it in order to know for sure. Or if you have access to high air pressure you can try to clean your burners and see if that eleviates the problem. But you saod it has done it since new. I am leaning towards a weak/ or stuck diaphram in the gas valve.
Feb 16, 2009 | Cozy (W352E) Heater
My Cozy Heater sized and installed by professional will not heat
I'm assuming your heater is the little Cozy direct vent wall furnace, your room calculations are correct, and at 57 degrees your main burner is constantly on. If so, it sounds as if you have too low a flame which can be caused by a main burner jet with an undersized orifice (like a propane one that got in the wrong assembly line) or obstructed by dirt, inadequate gas pressure, or a main gas valve that is not fully opening.
Open the pilot light inspection door and look at the main burner flame height. If it is less than 2 inches or so, check out the three possibilities above. If the flame is very yellow and wandering around lazily, check the air intake on your vent cap for obstruction.
Jan 31, 2009 | Cozy (W352E) Heater
Help it's cold here in Ohio
The "wire" you broke is probably the tube for the pilot assembly. It supplies gas to the pilot which in turn fires the burners thru a gas valve. The other option is you broke the thermocouple which causes the gas valve to open (its a safety feature incorporated to keep gas explosions from happening). You will need to replace the broken part before using this unit--period. It is not worth the danger involved trying to bypass these safety measures. BE SAFE!!!
Jan 14, 2009 | Cozy Enclosed Front Console Heater 70,000...
Cozy 351A 35000 btu
You might have a slight odor of gas when the burner first ignites. Some gas does escape before it completely ignites. It shouldn't smell after 2 years of use. If you can see the pilot flame burning from the top of the heater, the heater pilot assembly is pushed over too far. The pilot fumes could be escaping in the room and cause a smell.
Dec 27, 2008 | Cozy Enclosed Front Console Heater 70,000...
When unit goes on, there is a slight odor of gas when the valve
Cozy cheapened their heaters awhile back doing away with the air shutter. Without the shutter, a little gas can seep out into the room before it ignites and cause an odor. As for the curing odor, can you see the pilot flame looking down from the top of the heater? The pilot should be well inside the exchanger out of view. If you can see it, fumes from the pilot are getting into the room causing an odor. I had to remove the plate that holds the pilot assembly and drill a new hole shifting the plate over where it belongs. It was poorly assembled at the factory. Hope this helps.
Every time the thermostat tries to switch the heater on, the pilot light goes out. Cozy natural gas mod # CDV 335A
remove the thermostat wires from the gas valve and put a wire accross the outer terminals if unit starts up the stat or stat wire is bad.
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Cozy one sided wall furnace (no blower motor)
This is a weird one, but make sure all the wire connections are in the correct place. I accidentally miss wired a heater like this and it did the same thing.
Nov 27, 2007 | Cozy (W352E) Heater
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
195 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
