Question about Panasonic Link2Cell Dect 6.0 Plus Cordless Phone System - DECT 6.0
Hi - I have a KX-TG7621 Dect 6.0 phone system, that's about 2 month old. A few days ago, although we have a dial tone and people on the other end of the line hear us, we cannot hear them. It's
I have already checked setting of volume( incl mute) Also the line connected.
SOURCE: Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
Posted on Dec 22, 2008
guru_fixya
  • 944 Answers
SOURCE: i hv a totally blank
Just Re-Register it.
First reset the phone and re-Register the phone to the base.
Unplug the base unit from the wall (both power and phone lines) for 30 seconds
Here is the manual and just follow how to register it.
http://www.smarthome.com/manuals/971333.pdf
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Feb 11, 2011
  • 20 Answers
SOURCE: Panasonic 6.0 dect phone model # KX-TGA641 says
Remove the batteries from all of the phones, put them back in one phone at a time. If this doesn't work, try the phones somewhere else, aka a friend/employer. If they work somewhere else, the issue is with your household phone lines. If not, you should have the phone set repaired.
Posted on Mar 06, 2011
caroldon
  • 17130 Answers
SOURCE: Have panasonic model KX-TG7431. In-use
The In use display on the hand set confirms that the hand set has a faulty message.
Now if the telephone line is checked , it must be about +50 volts . Now if the line on connection drops to less than +10 Volts then there is a short in the dialer.
If on removal the voltage comes back then it is confirmed..
Now there is a dialer IC and a switching device- can be high speed switching transistor. Please check the transitor and the IC for short or that they trigger with a false signal.
If so disconnect the signal that switches to trace it to the dialer or the processor IC.
Only if the line to the phone is connected and shows the full voltage then the fault is isolated and the disconnected components or section must be probed.
Posted on Apr 08, 2011
fgrixti
  • 89 Answers
SOURCE: my panasonic cordless phone model # KX-TG2258S the
Do you even hear white noise? If not, it sounds like your phone's speakers may be broken, or it has water damage. If your landline is connected to more phones, ask yourself these questions:
Do all of the phones have this problem? If so, it's a problem with your connection, not the speaker.
Is there a volume button anywhere on the phone or the base? Try turning it up.
Do my phones make a "beep" noise when i push the buttons? If not, did they used to? If they don't, then it's likely that the speaker is no longer working properly.
You may need to contact panasonic and see if they will replace it for you.
Hope this helped! Please rate my solution!
- Frankie
Posted on May 06, 2011
Panasonic KX-TCD220E - pulsating busy signal for a few seconds then dial tone
If that pulsating tone is anything like what I sometimes here on my phone, then it has nothing to do with your phone. It's your telephone company telling you that there's unheard voicemail on their system. You'll need to contact your telephone service provider for instructions on how to access their voicemail system.
Apr 10, 2012 | Panasonic Lands Phones
Panasonic Dect 6.0 Plus has stopped working. It was working fine, but now the receiver doesn't hold a charge, and I can't get dial tone.
The rechargeable battery pack in the receiver needs to be changed, replace with genuine for optimal performance.
Jun 13, 2011 | Panasonic KX-TG1033S Cordless Phone
How do I program different ring tones for the KX T7220. THere are 6 to choose from I believe.
1 Press program key
2 Dial 99
3 Press line key or intercom key twice
4 Dial 1-8 for tone type
5 Phone will ring with new tone
6 Press store button(autodial)
7 Press program key to end
Dec 07, 2010 | Panasonic KX T7220 Corded Phone
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Aug 01, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Dropped calls, and no dial tone on Panasonic Dect 6.0 phone
I am sure that is a service related issue and no the phone itself.
Apr 26, 2017 | Panasonic KX-TG1033S Cordless Phone
No dial tone. No calls. Can't call out.
E4 IS AN ERROR MESSAGE, THE BASE IS NO LONGER GOING TO WORK, POSSIBLY A POWER OUTAGE COULD OF DAMAGED THE BASE.
Dec 28, 2008 | Uniden Cordless Phone
My KX-TG 8231B
Make sure the phone is pluggd into the wall properly. If so and no dial tone is detectable make sure you installed the batterys on the handsets correctly and that they are fully charged. If you have a friendly neighbor with a working phone line plug youre phone into their line and if it does not work and you followed my previous instructions seek a repair center in youre area that honors panasonic warranties. If the phone is pluggd in at the neighbors house and it works use it to call the phone company.
Mar 26, 2008 | Panasonic KX-TG1033S Cordless Phone
Panasonic Link2Cell Dect 6.0 Plus Cordless Phone System - DECT 6.0 Logo
63 people viewed this question
Top Panasonic Cell Phones Experts
Rommel Balcita
Nagendra Baliga
Andrew Taylor
Andrew Taylor
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
