Question about Orion PM4042 42 in. Plasma Television
My picture wont come on it had volume but now its gone aswell
Orion tv/37094 37 in . lcd television
Windows 7 driver for orion SLED2468W
Settings usually with a good USB cable, the settings on your TV when doing input go to USB where pictures and cable will show and connect from your computer to the back of TV and if doesn't work call TV company they always know the hook to this.
Aug 13, 2015 | Orion 24" Class LED-LCD 720p 60Hz HDTV,...
While watching TV we got sound and the TV stoped working.. No picture.. when we turn on it makes noise..but no picture..what could be the problem.. Do you the lamp is gone.. or some other problem..
IT may because of over heating and more alternate current.....the picture tube is gone away from which video is not seen and speakers are tered due to high volume it seems so but do take that channel you are watching is consists of a channel.....otherwise without channel it ll make sound possibly......
Jan 20, 2011 | Sony KDF-E55A20 55 in. LCD Television
My tv has volume but no picture. When i turn it has the picture for like 2 seconds then it goes black. But the volume stays.
Pic flash is a symptom of back light inverter fault. The unit will need to be bench tested to clarify. Usually the transformers, mosfets or a pf has gone and will need to be replaced.
Apr 26, 2010 | Proscan 32LB30QD 32 in. LCD TV
My volume wont work
Sound IC problem. or main processor problem.
Check reloading the software. Refer to manufaturer
Mar 30, 2010 | Vizio VA26L 26 in. LCD HDTV
What is the code for sky remote to operate orion tv-32082 a
please follow the steps below:
TV
RED + SELECT
TV
0236
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Aug 13, 2009 | Orion PM4202 Television
I was watching my tv when the picture just went of, but the tv is still on and sound has gone aswell.
well, normally I'd say you broke a dlp lamp. but since the sound is gone too, you might have a faulty power cord. try checking/replacing your power cords.
May 18, 2009 | Panasonic PT-52LCX66 Projection Television
Tuning in SKY remote control with Orion TV
buy a better telly
looooooooooooooooser
Dec 17, 2007 | Televison & Video
Dmtech 20 inch lcd tv dvd
These problems ocour when the inverter of Cathode tube fail in lcd tvs basically the tv need an inverter (mot likely)
Dec 04, 2007 | Televison & Video
Orion PM4042 42 in. Plasma Television Logo
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
