Question about Samsung Digimax A402 Digital Camera
I have a memory card inserted which shows the photos on it.However when I try to download it tells me there are no images how can I fix this problem?
    President:
  • 2,976 Answers
Make sure the pictures you are looking at are on the card, not the internal memory. Try to transfer them to the card using the setup menu. Change the default save area to memory card not internal.
Posted on Dec 13, 2012
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: MEMORY FULL
Talking about the Camera only here Check the manual for internal memory use. Put the memory card in. Use the menu button to switch between internal and card If your computer is XP you do not actually need any software to read the camera. Check the manual re this
Posted on Sep 27, 2007
  • 102366 Answers
SOURCE: I took a picture with
Press the play mode button and then press the menu button. Use left/right to select the [COPY TO CARD] menu tab.
Posted on Sep 24, 2010
LongPockets
  • 1177 Answers
SOURCE: i have the samsung s630
If you remove the card from the camera and connect the camera to your computer with the USB lead, you should see the camera's internal memory as a disk drive on the computer. If there is a memory card inserted, you will see that memory instead.
Unlocking individual pictures is done with the same function that locked them. It is probably on a menu available when you are viewing the pictures on the camera.
Posted on Oct 20, 2010
  • 147 Answers
SOURCE: my memory card is showing no images and card error
For how long have you been with this memory card? Memory cards have a life span and yours might have done that.
Posted on Nov 19, 2011
I removed batteries, and now images are gone, can I retrieve them?
Google 'Undelete program photos'. Some are free, some you pay for. The paid ones tend to be better, so it depends how much the missing images mean to you. Put the program on your computer, connect the camera and tell the program to search the hard drive on the camera. It will Undelete any image that hasn't been overwritten.
Nov 23, 2015 | Nikon COOLPIX L19 Digital Camera
My card has pictures on it, but when I press playback button & turn dial it does not show an image.
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Mar 29, 2013 | Canon EOS 30D Digital Camera with 18-55mm...
When cmera card is inserted into SD port can't download images
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Oct 04, 2012 | Compaq Presario R3000Z Notebook
Can't see images on laptop
Aug 14, 2012 | Cameras
The display shows that the card is not formatted..Format card ? How to solve this ? When I proceed to change the format.. It comments that the images will be deleted. I'm in need of those images.....
Aug 08, 2012 | Nikon Coolpix L24 Black Digital Camera 4gb...
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
How to upload photo
Transferring images from a Memory Card to a Windows Computer Follow the steps below to transfer images from a memory card to a computer running Windows. Step one: Insert the memory card Follow the steps below to insert the memory card into the HP All-in-One.
  1. Turn the memory card so that the label faces left, and the contacts are facing your HP All-in-One.
  2. Insert the memory card into the appropriate slot on the HP All-in-One.
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass-storage port on your HP All-in-One. These read-only partitions are added by the drive manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive. When the memory card is inserted correctly, the Photo light next to the memory card slots begins to blink. The message Reading... appears on the color graphics display. The status light next to the memory card slots blinks green when the card is being accessed. If a memory card is inserted incorrectly, the status light next to the memory card slots blinks amber and the color graphics display shows an error message such as Card is in backwards or Card is not fully inserted. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. Safely remove a card only when the status light next to the slots is not blinking.
Step two: Transfer images without using the HP Photosmart software After inserting the memory card into the HP All-in-One, the memory card appears as a drive on the computer. Follow the steps below to transfer the images on the memory card to the computer.
  1. Press the Photo button to display the Photo menu.
  2. Press the down arrow button (c01133817.jpg ) to select Transfer to computer .
  3. Follow the prompts on the computer to complete the transfer of images.
    NOTE: If there are photo files on the memory card that have never been transferred before, a dialog box on the computer asks whether you want to save the photo files to the computer. Click the Transfer option and all the new photos from the memory card are saved to the computer.By default, the image files are saved in month and year folders depending on when the photos were taken. The folders are created under the C:\Documents and Settings\username\My Documents\My Pictures folder.
Dec 08, 2010 | HP Photosmart 3210 Printer
Retreiving deleted pictures
You can use Image Rescue to try to recover the deleted pictures. Image rescue software can be located/downloaded from this link: http://www.mydigitallife.info/2008/10/28/free-download-lexar-image-rescue-3-to-undelete-and-recover-lost-photos-and-videos/
Hope this helps,
Andrew
Don't forget to vote
Feb 17, 2009 | General Electric A735 Digital Camera
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Dec 30, 2007 | Canon PowerShot SD200 / IXUS 30 Digital...
Samsung Digimax A402 Digital Camera Logo
35 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
