Question about George Foreman GRP99BLK model GRP99 Next Generation Grill with Removable Plates, 100 square inch grilling surface, 96 inches of cooking surface, Digital timer & temperature control, 2 dishwasher-safe removable grill plates and 1 floating hinge, UPC Code 08284603278
High pitched noise when plugged in
Changing outlets same results
  • Melinda Ricker Dec 14, 2012
    The readout is NO AC
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Wall plug for TV buzzes
Have the outlet checked by a qualified electrician. Sounds like either a power issue or ground. You should not get a buzz from an outlet for any reason.
If you plug something else into the outlet does it make the same noise?
If yes, something going on with the power. If not, then the TV power supply might be doing it, but the noise would be behind the TV and not the outlet.
Aug 17, 2014 | Sony Bravia 32-55 Inch...
High Pitched Noise Coming from Sony STR-DH510 LCD Screen - how to fix?
Hello
The problem is with its backlight inverter board. there are some step-up transformeres [small ones] fitted on board. If any one's core bacome loose this fault will occur. Just open the TV and listen to which one makes hi-pitch noise. Replace it, if you can buy it from the electronic market at your town. In most cases, the inverter board needs replacement.
This board can locate on the right or left side of the panel, fitted vertically.
http://www.dataentryjobs.us/67948.html
Feb 17, 2012 | Sony Audio Players & Recorders
How do I fix a high pitch noise when spinning?
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings.
Jan 28, 2011 | Asko W6222 Top Load Washer
High pitch noise emitting from tv
Change outlets or use a safety plug.
Feb 09, 2010 | Zenith B27A11Z 27" TV
High pitch sound coming from circuit board, cannot
First, you will want to isolate the problem. Is it feedback from an AC outlet you have it plugged into? Is it a recent noise that just started with no changes to Tv or its environment, then you may want to consider that a circuit is going and decide if it is worth repairing, You should find that type of fix at a shop for under $100
Sep 27, 2009 | RCA F35317 35" TV
Y rca 27f500tdv tv high pitched noise
Change the horizontal IC are damaged
Jul 28, 2009 | Televison & Video
My new Acer P191W LCD Monitor has a high pitched whine that is extra loud on pages with rich and dark colors.
The PSU "power supply unit is taken on a lot of noise from the outlet. Can you tell us if you have it streight plugged into to a 120V AC outlet or is it plugged into a strip? The Solution for both is NEW strip i recommend APC or plug it into a strip and check the outlet and make sure its properly grounded this should shore up this problem or the unit itself is going out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 24, 2009 | Acer P191WBD LCD Monitor
Wont turn on and high pitch noise
Looks like the printers internal electrical components have gone. if there is a tranformer in your printer then that is making that noise. or else even the motors might also be gone.
my strong suggestion take it to any authorized service personnel
Apr 20, 2009 | Computers & Internet
George Foreman GRP99BLK model GRP99 Next Generation Grill with Removable Plates, 100 square inch grilling surface, 96 inches of cooking surface, Digital timer & temperature control, 2 dishwasher-safe removable grill plates and 1 floating hinge, UPC Code 08284603278 Logo
Top George Foreman Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a George Foreman Hardware and Accessory Expert? Answer questions, earn points and help others
