Question about TP-LINK TL-SF1008D 8-Port Ethernet Switch
How to configure my router
Passvord
Bios locked plis passvord for an locking
The password is whatever the owner of the computer set.
Feb 07, 2016 | Computers & Internet
My passvord irresess
Here's how to change it:
  1. Go to your Yahoo Account Info page.
  2. Enter your Yahoo ID and password.
  3. Under "Sign-In and Security," click Change your password.
  4. In the fields provided, enter:
  5. Click Save.
Thanks.
TechSupportMart
Feb 27, 2014 | Yahoo Mail
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
Cannot connect to 192.168.0.1
How you connect to the router configuration page is depended upon how you have your router management configured. I believe by default belkin routers allow for remote configuration so if you didn't configure any security on your router someone may have altered your configuration.
The default method for configuring your router requires.
  • An ethernet cable plugged from your computer to a LAN port on the router
  • The correct Gateway address (Start > Run > Type "CMD" at the command prompt type "ipconfig" look at your gateway address
  • In a web browser type in http://192.168.0.1 in this example
If you still can't access it I'd suggest pressing the reset button on the back of the router and re-configure the router in case of tampering.
Comment if you need any further assistance
Oct 27, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
Please send call barring passvord
Please supply more information about the nature of your problem.
What hardware are you using?
What software are you using?
What error-messages do you see?
Nov 20, 2010 | Computers & Internet
Login end Passvord
Username: EAV-31659959
Password: 35sammvjn7
Expiry Date: 03.12.2010
Nov 12, 2010 | ESET NOD32 Antivirus
I forgot my user name and passvord of setings
Go ahead and send it off to the manufacturer. They will recover it for you hopefully.
May 06, 2010 | Western Digital My Book Home Edition 500...
Maseehrahi
Hi, just visit this link and follow the steps: https://edit.yahoo.com/forgot?login
Regards, polysandy
Mar 25, 2010 | Yahoo Messenger
Router configuration
i sujject you learn CCNA - cisco certified network associate course ware .. then you can configure most of the routers with slight syntax changes
good luck
Jan 15, 2008 | Actiontec GT704WG Wireless Router...
TP-LINK TL-SF1008D 8-Port Ethernet Switch Logo
57 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
Robert
Level 1 Expert
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
