Hp Design Jet Z6100ps. Has 03.10 error. I have replaced the service station and Print Mech. Still errors on start up. All power supply fans are working. Help?!
  • 7,627 Answers
Soulvisitor
  • 1113 Answers
SOURCE: Printer HP Laser Jet 7400
A critical firmware error has occurred that caused the processor on the formatter to abort the operation.
This type of error can be caused by invalid print commands, corrupt data, or invalid operations.
In some instances, electrical noise in the cable can corrupt data during transmission to the printer.
Other causes include poor quality parallel cables, poor connections, or specific software programs.
99 % of time it is a corrupt file or poor connection, I have also known it to be the firmware, dimm or formatter board on rare occasions.
Recommend check hp web for any firmware updates, check connections and that driver is installed impecablly and use known good files to test.
Posted on Dec 27, 2007
faxman789
  • 297 Answers
SOURCE: getting a system error 1180
System Error 1180: Capping Motor Error
Description:
Capping Motor over current is detected.
Corrective Action: Try the following:
When the ambient temperature is very low, the Pump Motor Tube becomes hard and the load on the Capping Motor is increased. Make sure that the Printer is in an environment where the temperature is not below -10oC or higher than +85oC.
The Capping Station has a Torque Limiter for up and down operation so that the Capping Station does not experience any over current. Apply grease on the shaft of the Capping Station Gear so that it helps with rotation.
Make sure that the Capping Station cables are connected correctly and are not damaged
If the Capping Motor cannot be rotated, replace the Capping Station
Replace the Main PCA if nothing above corrects your problem
Posted on Jan 15, 2009
POCBM
  • 121 Answers
SOURCE: HP 2500C Pro Series Color Ink Jet with Error Code 432
The problem is with the service station. This is the unit that the carrier "Parks itself" over when it is not printing. It cleans the print heads and collects excess ink. It also fills up with ink. and the ink dries in a big blob.
If the motor is good, if it was working it likely is, The SS probrably got jammed in the move.
Try this:
If you can move the carrier to the left with power off do so.
If not turn machine on and while carrier is to the left unplug the machine.
You need the carrier to the left to expose the SS.
Open the cover as if you were changing printheads.
Look straight down. your looking at the service station.
A shaft with wipers and a gear at one end should turn. A little resistance but jam if alot of ink is caked in the bottom of the unit.
You can clean some of this in from the top and see if the SS frees up as a test at least.
The service station can be removed if required. You need to remove the right cover from the machine.
There are three screws that you should see looking down at the SS from the top They have numbers next to them I beleive, holding the SS in. Everything that moves should move freely.
Hope this Helps Good Luck
Posted on Mar 11, 2009
  • 75 Answers
SOURCE: HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
Posted on Nov 04, 2009
  • 6 Answers
SOURCE: HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Posted on Jul 20, 2010
Hp 500ps severe error code Ox40d0003-
If any of the troubleshooting steps listed below solve the problem, attempt to verify printer functionality (instructions listed below). If functionality is verified, no additional parts should be replaced.
    NOTE: Always verify the printer's current Firmware release and upgrade as needed.
    1. Turn the printer off, then on to verify error. If no error attempt to verify functionality.
    2. If the error appears or problems persist, continue with the remaining steps.
    3. Turn the printer off, and disconnect the power cable.
    4. Remove the right end cover.
    5. Check both Ink Supply Station connections on the Interconnect PCA. If the unit shows the error on boot up verify that the connector with the blue wires is seated correctly (Connector P4). If the error appears when a print job is sent to it verify that the connector with the red, black and green wires is seated correctly (Connector P2).
    6. Reconnect the power cable and turn the printer on.
    7. If no error appears, attempt to verify functionality.
    8. If the problem persists, continue with the remaining steps.
    9. Replace the Ink Supply Station (refer to pg. 8-48 of the HP Designjet 500 and 800 Series Service Manual).
    10. Following replacement, attempt to verify functionality.
    11. If the error reappears, replace the Electronics module (refer to pg. 8-24 of the HP Designjet 500 and 800 Series Service Manual).
Jan 02, 2017 | HP DesignJet 500ps (42 in.) InkJet Printer
Error code 21.1: 03
Service Station problem.
You might have to replace the "service station" or the "print mech"
You need a tech
Jul 15, 2014 | HP DesignJet T620 - large-format printer -...
Error code showing 21:13 in designjet T620
There can be three solutions to this problem:
1. replace your service station
2. replace the print mech pca
3. replace the main pca
In that order. hopefully you can get this on the first repair (service station). this can become expensive. Let me know if this helps.
Aug 18, 2012 | HP Office Equipment & Supplies
I have a HP Z6100, and I got many times error 86:01 possible paperjam, after changing encoder strip and encoder sensor, carriage PCB. I still have 86:01 error, after Scan Axis in maintenance mode, the...
Observe when 86:10 error appearing? after intializing the carriage or immediately after powering on?
# If immediately error appearing do the below discussed activity
# after intializing if error appearing check trailing cable,service station wipers & cappings,cutter position, cutter movement & lubrication on rail.
Detatch power cable & data cable,remove right door, pull out carriage assembly from service station area (if its locked by service station manually unlock it). Remove cable connections, screws & take out service station from the printer.Place the service station out side(ensure that cables has to fix properly) connect the cables,switch on the machine, check for the error..
if error is not appearing: check the service station, found any damage replace it or shoot the problem.fix it back..
*even error is appearing: Remove carriage belt from the pully..check carriage movement, if found any hardness/obstruction? shoot the problem.
Finaly: check trailing cable( while carraige movement some tracks may lose their continuty)
Power supply.. ( check voltages)
Need your feedback for further help.. vinay229229@yahoo.co.in
Apr 11, 2012 | HP Designjet Z6100ps InkJet Printer
My design jet 500 says I am out of ink, when in fact 3 of 4 are full, why does this happen and is there a way around this issue
hi, for this issue to resolve power off the printer , remove all cartridges check the contacts in the ink station assy,try cleaning with a lint free cloth,try replacing cartridge and if the issue still persists conduct service test for ink station assy if the result is negative replace the ink station assembly. You could also get repetitive Ink Cartridge Error messages if the Ink Cartridge is leaking.
Venkateshwar, hp technologist, contact:+91 0086427911
Sep 21, 2011 | HP DesignJet 500 InkJet Printer
Error code 21:13 restart the printer if the problem persists,call hp support
It all depends on the machine but typically all the 21 errors relate to the service station. this is the part to the right of the machine that "caps" the carriage and print heads when the carriage parks after a print. 13 refers to power cycling the machine to reboot it. If you need more precise info you will need to post the model and more info.
Aug 25, 2011 | HP Designjet T1100ps Printer
Morning printer read error 57.04 this is hp laser jet p 4015x
57.04 ERROR means that Fan FN101 has experienced an error (Fan FN101 is at Left side, toward the rear)
To continue turn off the printer and then on
HP recommends the following steps for trouble shooting: -
1.Inspect fan FN101 to determine if its rotational movement is being obstructed.
2.Verify that the fan connection at connector J64 on the power supply PCA is securely seated.
3.If the error persists, replace the fan
HP 4015 Service Manual
Refer Chapter 7, PG-286 for additional details
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 14, 2011 | Office Equipment & Supplies
I have an HP design jet 70 showing error code 2210 any help would be appreciated.
22:10 Ink Supply Station failure.
Get the Ink Supply Station replaced.
Get a tech to do the work. You will not want to do the work yourself.
May 05, 2011 | HP Designjet 70 InkJet Printer
HP T610 21:13 ERROR - THE SERVICE STATION DOESN'T MOVE ANYMORE IT'S JAMS
there can be three solutions to this problem. replace your service station, replace the print mech pca, replace the main pca in that order. hopefully you can get this on the first repair (service station). this can become expensive. let me know if this helps.
Jul 19, 2009 | HP Designjet T610 24-in printer InkJet
Try this:
Feb 27, 2009 | HP DeskJet 2500C Pro InkJet Printer
328 people viewed this question
k24674
jasbo
jasbo
