Question about Toshiba Satellite Computers & Internet
Toshiba satellite M305 S4907 comes on but monitor is blacked out can barley see
  • Toshiba Master
  • 5,660 Answers
Http://www.screentekinc.com/Toshiba__Satellite__M305-series-laptops-lcd-screens.shtml
The Toshiba Satellite M305-S4907 Notebook PC, uses a single CCFL for a Backlight.
Primer before we go on;
An LCD screen cannot produce light. It needs an additional light source,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor image.
The additional light source is a Backlight.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 8 photos.
A screen Inverter is used on laptops that use CCFL for Backlighting.
A screen Inverter converts the power (Electricity), from the laptop, for the LCD screen, and Backlight.
Laptops that use a series of LED's for backlighting, do Not use a screen Inverter.
90 PERCENT OF THE TIME the fault can be attributed to a bad screen Inverter.
http://www.sparepartswarehouse.com/Toshiba,Satellite,M305-S4907,PSMD8U-02R015B,Laptop,Inverters.aspx
The plastic thin frame in front of the LCD screen, is the Display Bezel. (Toshiba = LCD Bezel)
The screen Inverter is located behind the Display Bezel, and mounted at the bottom of the LCD screen.
(LCD Screen Frame, actually)
Easy to get to; easy to replace.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M305/remove-screen-inverter-video-cable-1.htm
How to test a screen Inverter? Requires a Sensitive multimeter.
Read fairly expensive,
http://www.fonerbooks.com/test.htm
Because of this; and the low cost, plus ease of replacing; most home users just opt to replace it.
Know this;
Fluorescent lamps have MERCURY inside. HIGHLY poisonous.
Now couple that with the long thin makeup of the CCFL, and how easy it is to break it.
This is why if the screen Inverter is found to NOT be the problem; I would suggest replacing the LCD screen itself; instead of trying to replace the CCFL, and cause possible Mercury poisoning.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Dec 12, 2012
Fixe_You
  • 1800 Answers
SOURCE: INSTRUCTIONS ON HOW TO BURN CD FOR MY LAPTOP
its very easy u can download the latest version of nero its an amazing software of burning cds and DVD
free trial of Nero
Posted on Mar 05, 2009
sys_admin
  • 829 Answers
SOURCE: monitor went black
Try reinstalling the Display
driver
Posted on Mar 31, 2009
SOURCE: error code when creating recovery disc
smash it, lol, i hate some computers, by the way im just kidding i have no clue what to do!
Posted on Jun 23, 2009
leecom72
  • 4806 Answers
SOURCE: Toshiba Satellite P105-S9722. monitor will not
The problem is the inverter cable or the inverter itself.
If you have any warranty left on the laptop then i recommend you take advantage of that and send it in for repair, or you can deal with this 2 ways.
Fix the problem yourself.
Remove the screen bezel (plastic screen surround), this will reveal the whole screen. At the bottom of the screen you will see an elongated piece of circuit board with wires coming from either end covered by frosted plastic.
That is the inverter, check the connections on the inverter and power the laptop up to check the display, to remove it gently pull the plugs from each end and remove the screw from the middle and pull the board away.
Look at the inverter for a copper coil, if you re-solder the solder points around the coil you may find it works again as components that suffer from extreme heat the solder joints dry causing bad connections, re-floating the solder solves the problem in 90% of cases.
Take the laptop for repair.
In this case all you have to do is source a reputable PC repair store and take it in for them to fix. (it should be fairly inexpensive).
Good luck.
Posted on Sep 02, 2009
parrotheadpc
  • 2600 Answers
SOURCE: My new Satellite M305-S4910 is experiencing a
Remove the power strip above the keyboard and the keyboard and remove the bezel on the LCD. This will give you a clear view of the wiring leading from the screen to the motherboard. Look for a loose connection or rubbed or frayed wiring. Also, a lot of video problems are from the cable getting loose that runs from the back of the screen. This is a flat cable the fits in a socket on the back of the screen.
Here is the lcd removal duide for your laptop....
Posted on Sep 22, 2009
SCREEN IS WHITE
Sounds like an un-seated video cable. Try an external monitor. If it doesn't display on an external monitor, the the system board is likely defective. Otherwise, you'll need to locate the video cable and reconnect them to the board.
Nov 08, 2012 | Toshiba Satellite L310 M300 M305 U400 U405...
Toshiba Satellite m305-s4910
remove the battery pack and power source. make sure nothing is plugged into the laptop. hold down on the power button for 30 seconds. then reinstall battery, plug the the adapter into a known live power source (the real reason for your problem) and power it up!
Jan 16, 2012 | Toshiba Satellite M305-S4826 Laptop
Need to replace the wires that connect the lcd screen to my laptop computer anyone know where i can find such a part? toshiba satellite M305-S4848
Hi gent010
SOURCE FOR TOSHIBA LAPTOP SPARE PARTS
Here is the link to Official Toshiba Repairs Support Website with the contact details and link for Toshiba spare parts:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/navShell.jsp?cf=su_rc_spareparts
Here is a list of regional Toshiba spare parts distributors:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/navShell.jsp?cf=tv_parts_distributors
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Oct 03, 2011 | Toshiba Satellite M305-S4826 Laptop
Toshiba satellite m305-s4910 flickering toolbar
My M305-S4910 was doing the same thing. After some research, I replaced the video cable. The flickering was not as bad, but still there. I just replaced the inverter, and the pink line beneath the toolbar is now gone and so is the flickering. :-)
Sep 13, 2011 | Toshiba Satellite M305-S4826 Laptop
I have a toshiba satellite m305 s4848 and i need to restore the factory settings
what exactly do you mean by factory settings? Are you looking to install a fresh copy of windows or just reset the bios on the motherboard?
Sep 08, 2011 | Toshiba Satellite M305-S4826 Laptop
I cannot get my Toshiba Satellite M305-S4910 to switch its' display to a stationary monitor. Is there something I need to do besides plug in the monitor cable?
Are you in windows 7? If so, hold the windows key and press P. Select the monitor output configuration you want (being careful to make sure you can still see the screen on something).
If you lose the screen entirely, unplug the vga cable and reboot the computer.
May 26, 2010 | Toshiba Satellite M305-S4826 Laptop
My notebook camera for my laptop (toshiba m305-s4907) doesn't work and everytime i try to launch it, it doesn't launch.
big red
have the same problem here it only worked the first couple of times then hasent worked since took it to geek ssquad told me that it just burned out wich suxs
Oct 25, 2009 | Toshiba Satellite M305-S4815 Notebook
My new Satellite M305-S4910 is experiencing a monitor flickering. What can I do to stop it flickering?
Sep 22, 2009 | Toshiba Satellite M305-S4826 Laptop
Umm... You need a program like Nero to burn anything to CD. Start with that first and the rest will fall into place for you.
Mar 05, 2009 | Computers & Internet
Computers & Internet Logo
154 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
