Question about HP LaserJet 4 plus Printer
Can i connect hp laserjet 4p via usb ??
Can i use a usb to centronix parallel cable to connect my hp 4p printer to a modern pc? i have tried an failed so far but that was using a serial to usb cable in its serial port. i havent got a parallel to usb cable at the moment and wondered woudl it work before buying one.
thansk for any help
  • bjrapoport Jan 22, 2009
    I connected my new compaq laptop to my HP 4 plus using a parallel to USB cable. Sometimes it prints, but mostly it doesn't.
    I have deleted the printer several times & tried to start over. I have even connected the printer after Win Vista has booted up. The first time it printed. Then next time it didn't. So I connected the printer again after Win Vista has booted up and it did not print this time. Is it Win Vista or what? HELP! Thanks.
    Betty
    email: bjrapoport@hotmail.com
I have a similar situation. Trying to print from a HP LaserJet 4 using a parallel cable to USB. It will not recognize the printer. What is the installation setup or what is the trick to get it to print?
Posted on Apr 15, 2010
  • 55 Answers
Yes it will work. I know we have had to do that at our office before. You can find usb to parallel cables online like Tigerdirect.com and some other places. You can also get an adapter as well. If you need more help let me know.
Posted on Jan 13, 2009
Connecting with usb port
try a usb/
Parallel Printer Adapter Cable
cable you can find them at office supply stores or others such as walmart.
http://www.walmart.com/ip/15075022?adid=22222222227000586714&wmlspartner=wlpa&wl0=&wl1=g&wl2=&wl3=21486607510&wl4=&wl5=pla&veh=sem
Dec 16, 2012 | HP LaserJet 4p Printer
What kind of cable or usb do i need to connect my hp laserjet 3015 to my pc?
Hi,your printer use 2 different USB and parallel interfaces..I recommend to use USB cable..
Pls visit the below links for these cables..
Just in case ,I have provided an URL for user manual as well.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
USB Printer Cable for HP LaserJet P3015dnhttp://www.amazon.com/gp/product/B004PRSNRQ/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=1278548962&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0001M3QZS&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=04ARKGAPMW24ZWCCBNHN
Parallel to USB Adapter opens new browser window - Connect USB Printer to PC Parallel Port with LPT2USB Adapter ********************
HP LaserJet 3015 user guide - ENWW
www.lavc.edu/it/manuals/printer_hp_laserjet_3015_user_guide.pdf
Use these topics to acquaint yourself with your new HP LaserJet 3015 all-in-one
Jul 01, 2011 | HP LaserJet 3015 All-In-One Printer
Just got a new computer. Have an old HP Laserjet
you have to refer to usb/ parallel converter manual, not printer manual
Apr 07, 2010 | HP LaserJet 4p Printer
EtherFast Print Server manual
Other gurus might correct me, but I don't think this can easily be done. You are dealing with "parallel" data with the HP and "serial" data with the PC. If your HP has cards you can change, then conversion to serial data is relatively simple, otherwise...
Mar 29, 2010 | Linksys EtherFast 10/100 (epsx3/uk) Print...
Can I connect my HP laserjet 5p with a 25 pin connector to my laptop which only has USB connection
On the back of the printer where the cable connects is actually a 36 pin connector, the end going to the computer is the 25pin end. What you will need to do is get a USB to parallel cable, they run $15-25, this will have the USB plug on one end and the 36pin centronix printer connection on the other end. This cable will allow your printer to be connected to the laptop. Office Depot and Staples should have the cable you need, if not you can do a google search for it and order one online.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 26, 2010 | HP LaserJet 5p Printer
I have a HP Laserjet 4P that had been used on my company laptop and home computer. When I upgraded top a new Dell Vostro 420 running Windows Vista Business and moved the printers over to this unit the...
You don't write how exactly is your printer connected - if I remember correctly, HP LJ 4P doesn't have a USB connector, and Vostro doesn't have the parallel port available.
So how did you connect it? Is it via some USB to parallel adaptor, or via JetDirect network card in the printer? There are multiple separate issues that may be applicable in either case...
Dec 30, 2009 | Office Equipment & Supplies
Windows vista does not seem to recognize HP 4P printer
WOW!? HP4P... I don't think you'll find a Vista Driver for that printer.
Try www.hp.com in the downloads section.
Good luck from a crusty old HP Printer Tech.
Jan 22, 2009 | HP LaserJet 4p Printer
HP laserjet 2200D connected via USB gives problem
try plugging into another usb & reinstall the driver that may help.
Jan 16, 2009 | HP LaserJet 2200D Printer
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
HP Laserjet 3100 all in one USB driver / cable
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Also try with another USB cable, If you are using a long cable, just try with a short one.
Dec 17, 2007 | HP LaserJet 3100 All-In-One Printer
HP LaserJet 4 plus Printer Logo
982 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
