Question about Toshiba Satellite L675-S7048 Notebook
L675 toshiba satellite black screen problem
How to boot into safe mode
  • Toshiba Master
  • 2,878 Answers
Press F8 during boot.
Posted on Dec 12, 2012
  • 71 Answers
SOURCE: Toshiba Satellite won't boot up
While you have it in safe mode, make sure you back up all your personal data to a cd as is sounds like it is not going to last much longer. After you back up all your information....Documents, Pictures, Music...etc... Then I would reformat the machine with the original installation disc that came with the computer. That should fix the problem. Never even heard of a boot processor :)
Posted on Oct 10, 2008
Geekman
  • 32281 Answers
SOURCE: toshiba satellite a215s7422 screen blackout problem
As you can see an image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 06, 2009
todd0708
  • 247 Answers
SOURCE: Toshiba laptop satellite L300 Booting Problem
try the recovery wizard,also try pulling the hard drive,and ram,and bios battery if you can get to it,looks like watch battery on motherboard.or green plastic pack with two wire plug on main board,take the panels off on the bottom,if your lucky you will see it,otherwise have to dissamble to get to it.if you find it unplug for a couple hours,with main battery out and ac unplugged,should reset the bios to factory default ,might help ,do you have xp or vista?if your bios battery is the watch battery style be very carefull removeing it the holder will break off the motherboard easily,,if none of that works post a reply and ill give you some more options
Posted on Sep 10, 2009
lserni
  • 466 Answers
SOURCE: My Toshiba u205-s5002 does not boot all the way.
Unless you're familiar with Microsoft diagnostics and XP Recovery Console, I think that the quickest way to solve the problem is to use the XP CD and perform a "repair installation". Beware that the supplied CD disk is indeed an installation CD and not a "wipeout and reinstall" disk (many recovery disks are programmed like this, and using them will make you LOSE any personal data in the laptop!). If it is, you'll have to boot using a backup LiveCD (e.g. UBCD, http://www.ultimatebootcd.com/, or XP Rescue), backup the data on an external USB unit, and then do the recovery. On the plus side, this procedure is much more thorough than Windows' repair install. On the minus side, you'll have to reinstall any programs and customizations.
Try, however, to boot with UBCD and check the disk is intact first thing. It might also be a more easily solvable problem, after all.
Posted on Nov 24, 2009
Testimonial: "Thanks"
  • 107 Answers
SOURCE: Toshiba satellite L675 freezes after
Boot the computer into "Safe Mode".
To boot PC into Safe Mode follow these steps:
1. Turn the computer on or Restart the computer
2. Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
3. Ensure that the Safe mode option is selected, not Repair Your Computer
4. Press Enter. The computer then begins to start in Safe mode.
5. When you are finished with troubleshooting, close all programs and restart the computer as you normally would
If the computer boots into Safe Mode you can try disabling Startup Programs, one of these might be causing your computer to freeze. To do this follow these steps:
1 Press Start. Type msconfig into the search bar and press Enter. For XP, click on Run and type msconfig there.
Posted on Mar 30, 2011
Fix satellite c655 toshiba laptop lcd screens
If the start up menu displays, it could be a video driver issue. Try to start in safe mode ; press F8 at start up and choose safe mode.
Mar 29, 2013 | Toshiba Computers & Internet
Try these troubleshooting instructions:
  • Reinstall your video driver
  • Check for registry issues
  • Start the computer in safe mode and run System Restore
  • Removing the graphics driver in safe mode might work for you. Just remove it via Device manager.
To avoid this problem in future use PC optimizer Reginout. WebRepOverall ratingThis site has no rating(not enough votes)
Dec 12, 2012 | Toshiba Satellite L675-S7048 Notebook
My Toshiba Satellite L305 does not complete the boot process following the latest Windows updates. I get only to a black screen. Any suggestions?
I suggest that you do a system restore via safe mode.
If you don't how to go to safe mode, please follow the following steps:
1. Turn on your computer and tap F8. Keep tapping until you see the screen where you can find the option to go to safe mode.
2. Highlight safe mode and press enter.
3. when you are inside safe mode, do a system restore to the date when it was still working fine. It should work.
I hope this helps.
Carlo Adrian Canon
Nov 14, 2012 | Toshiba Satellite L305 (883974223084) PC...
My computer (satellite l515) will not load past the forest screen when you turn it on. (The black screen that says Toshiba) how do I fix this.
Re seat hard drive, and memory. tap F8 while the laptop is booting to go the safe mode. If it boots in to safe mode, you can run "Error checking" by clicking on computer> C: drive> properties> tools> error checking. Follow on screen instructions from there.
In your operating system it may have a different name. Please rate this information high if it was of help. thanks
Apr 19, 2011 | Toshiba Satellite L500 Series Notebook
I restarted my Toshiba satellite a305 and now it won't boot up or go into safe mode. It comes to the start up screen that says press f2 for setup f12 for boot manager. It will let me go into setup and boot...
If it won't let you go to safe mode,then there's something that the BIOS(setup) or Boot Manager needs before starting the operating system(Windows Vista). You should have a Toshiba Recovery Disk which will fix this . The disk will not touch any of your current files and data,so don't worry about that.
Apr 12, 2011 | Toshiba Satellite A305-S6908 Laptop
Toshiba satellite L675 freezes after startup. Windows &
Mar 30, 2011 | Toshiba Satellite L675-S7062 Notebook PC
Laptop shows Toshiba Logo, then Bios option, and then goes black
yes its very possible maybe the one u replaced was faulty?
Apr 08, 2010 | Toshiba Satellite P35-S611 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Black screen w/blinking cursor
So.. you can select safe mode? Or you turn it on and it is resuming into the blank screen?
If the latter. Unplug the power, pull the battery out for 20 seconds or so. Then put it all back together and try booting up.
Apr 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite L675-S7048 Notebook Logo
425 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
