Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Water in bottom of dishwasher
When I open my dishwasher in the morning, there is water in the bottom. I know all the water has drained out at the end of the cycle because, when I open the door when the cycle has ended, there is no water in the bottom. It seems to come in over a period of time before the next wash. I have no idea where the water is coming from or why. My dishwasher is only 2 years old. Can someone help.
I would agree with jsrock. It sounds like a problem with the valve.
Posted on Jul 20, 2007
  • 5,911 Answers
You could have a defective fill valve that is not shutting off properly. Look for a fill inlet opening somewhere on the inside casing of the wash tub. Usually it is on the left hand side of the machine looking in. While the dishwasher is sitting idle, watch the fill valve opening to see if water is leaking in. It could be a minor as just a drip. However, over a period of several hours you could end up with a wash tub full of water. Over a weekend with no one home, it could overflow onto the floor. The valve usually cannot be repaired and would require replacing. Good luck.
Posted on Jun 12, 2007
Not draining at all. water collected at bottom of unit. tried "cancel/drain" numerous times and water remains at bottom of unit.
Possible blocked waste pipes or cycle pipes. but some specialist de-greaser and let it soak in dishwasher over nite - put dishwasher on in morning, repeat until its flushed.
Feb 16, 2010 | Kenmore Dishwashers
I woke to water draining from the dishwasher this morning. I looked inside and there was water in the bottom? Help?
when you say you woke to water draining i assume the pump was activated if so you water valve is not shutting completely causing your dishwasher to gradually over fill this will cause your water level switch to activate the overfill stage and bring in your water pump have a close look and if this is the case replace water valve hope this helps let me know how you go
Nov 14, 2009 | GE PDW7380NSS Stainless Steel Dishwasher
Bosch logixx dishwasher draining constantly even with door open
there is a leak . when the unit stays in drain mode that means there is water at the bottom of the base. The float switch stays in drain mode untill the water is removed. you must take off the side panel to remove the water,let me know what happens.:)
Nov 08, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
I have a 17 - 18 inch dishwasher and the water runs out before the wash cycle is over. If I have not used it for a while, when I open it there is water in the bottom. What am I doing wrong??
I think your drain hose must be too low...the drain hose has to raise above the bottom of the sink..this keeps a air gap in the hose.. keeps the water from running out and will also keep water from the sink running into the dishwasher... let me know if this helps
Sep 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Water in bottom, and it wont turn on
my neighbor fix it, don't know how.
Jan 09, 2009 | Dishwashers
QuietPower 3, water seeps into unit,fills the base once per week.
I need more info but I would check the drain connection under the sink to make sure that it goes up after leaving drain , to keep the sink from draining into the dishwasher.
Dec 14, 2008 | GE 24 in. Profile PDW7800 Built-in...
Whirlpool dishwasher doesn't clean/drain.
sounds to me like a drain pump restriction or failure. let me know if this helps.
Nov 14, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Sears Kenmore Automatic Dishwasher: Models No. 14041 /14045 /14045... Problem:
Many dishwasher have their drainlines tied into under sink disposers. If a person caps the sink drain while dishwasher is running, it can back the water back to the washer keeping dishes dirty and backing up water
Jul 05, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Hi You have a drain problem, Your house drain may be restricted the dish washer pumps out with more pressure then the water just falling down your sink.I would snake it or have a plumber clean out that drain...let me know if this helps krazytech
Aug 24, 2007 | Bosch 24 in. SGS43C12 Classixx...
Indesit Dishwasher
disconnect the drain hose and lower it into a bucket if no water comes out there is a blockage in the hose/pump.
Jan 25, 2007 | Indesit 24 in. D63S Free-standing...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
374 people viewed this question
Top Bosch Dishwashers Experts
shaun taylor
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
