Question about DG D&G Prime Time Watch for Men
How to change the battery in D&G men's watch DW0280 model
I changed the battery of the above mentioned model watch,after that i couldnt fix the cover
Mens Armani Watch AR-0659 What battery fits this watch
I don't know the battery type for your watch but I would suggest you get the battery change done professionally. They can replace the seal and guarantee its continued water resistance on your particular model. Sadly I learnt the hard way and after the DIY battery change on my (now deceased) Armani watch it filled with water on my next visit to the swimming pool!
Dec 24, 2014 | Watches
How do u open back to fix an fossil black 5 atm fs-4351 hand watch
Jerry, If its smooth on the back cover, you have to pry it off carefully. Get a magnifying glass and look around the cover edge, there should be a small under cut. Pry at this point with a penknife blade or similar. If the cover has 6 or 8 small indentations in it then it likely unscrews but you may still need to see a watch shop for the tool to unscrew it.
Fossil watches have a 2 year warranty so if its inside this, take it to a dealer.
Nov 03, 2014 | Fossil Watches
How to change the battery in a kenneth cole 3504 watch
you have to open caseback, inside close to the battery see one tiny metal piece pressing & holding battery, you need a tiny pin to pry that metal piece battery will come out put new battery on then press VERY GENTLY 9k=
May 13, 2014 | Kenneth Cole Reaction KC3504 Watch for Men
FR60 garmin watch error message
No solution. I just tried to change my battery yesterday and am receiving the same message. If I get a resolution I'll post it. Just wanted to let you know you're NOT alone!
May 06, 2012 | Garmin FR60 Wrist Watch for Men
What is the battery for diesel dz2062
The battery inside my model was a Sony SR6265W. According to the Walgreen's website, an Energizer 377 is a replacement battery for battery mentioned above as well as several other models..
Dec 18, 2011 | Diesel DZ2062 Wrist Watch
Question 1:Well,this guy was gonna throw away this watch,so i asked him if i could have it.Now i have a Guess G65023G watch that doesn't work. I want to fix that. Problem 1:The minute hand turns when...
Well, thats a good watch. however, based on the conditions of your watch, probably, its battery is not dead. some of its mechanism were not in place or broken. Repairing it is advisable. Afterall it has no scratches like what you've said. So go for repair men!
Jun 09, 2011 | Guess G65023G Watch for Men
Need to open. coleman 40-334 watch not sure if the back is threaded
mcdevito75 here, If the back screws down, you"ll see a series of square holes around the edge of the back cover, in this case you"ll need a special tool called a case back remover tool to un-screw the back cover. If there are no square holes on the back cover, most likely it"s a press type back cover and some of these cavers are very hard to get back on wothout another tool called a case back press tool, these mentioned tools are available on ebay, but, with just a battery replacement, the time and tools you may need the cost is more than a watch repair shop would charge you. Best Bet, look for a small watch repair shop in your area for this once a year or even longer battery change.
Feb 11, 2011 | Watches
DG D&G Prime Time Watch for Men Logo
185 people viewed this question
Top DG Watches Experts
Ansel Alberto
Ansel Alberto
Are you a DG Watch Expert? Answer questions, earn points and help others
