Techwood plr85 cooling fan troublshooting - Audio Players & Recorders
SOURCE: techwood home theater remote code model #plr85
try 212, i have the same exact thing. I used the auto search remote codes method and it found and works on that code...
Posted on Jan 25, 2009
  • 1348 Answers
SOURCE: my techwood plr85 keeps saying PROTECT every time i turn it on.
disconnect the speakers one at a time and see if the protect goes off.there may be shorted speaker leads on the back of the amp or a speaker.a common thing is to hit the wires with a vacuum or furniture.once i saw someone hang a picture and put a nail right thru one of the wires that were installed when the home was built.if all speakers are disconnected and the protect is still on,then there is a dc fault in the amp and it needs to be looked at.the most common cause is a blown output transistor or ic
Posted on Jun 13, 2009
SOURCE: hi, my stereo is on standby mode and i cant get it
Hi, The problem could also be the thermal fuse inside the main power transformer (AC) is blown. I fixed same problem yesterday. If you have a meter u can check for continuity. Still need help? email me... ekwhoward@yahoo.com
Posted on Nov 10, 2009
SOURCE: Techwood 400 watt Stereo Receiver PLR85
the protect light keep comming on
Posted on Aug 21, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have A Techwood 400
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 21, 2011
Techwood Codes
0022,0000,9999. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Check this link too. http://electronicshelponline.blogspot.com/
Oct 22, 2013 | Televison & Video
I have a Techwood reciever. I need to replace the motor for the fan. Please tell me where I can order this part! Thanks a bunch! Diana
I believe that Techwood is no longer in business. You could try electronics site such as mcm electronics or encompass electronics for a fan.
Feb 09, 2011 | Audio Players & Recorders
I have A Techwood 400 watt Home Theater Receiver plr85. When you turn It on About 30 secends after that it mkes a poping noise, and then you cant hear anything .After that the word PROTECT Flashes How can...
Jan 21, 2011 | Audio Players & Recorders
My techwood plr85 keeps saying PROTECT every time i turn it on.
Jun 13, 2009 | Samsung HT-Z310T Theater System
My (Techwood 400 Watt Home Theater Receiver PLR85) won't turn on
I have had the same problem.
You have a faulty cooling fan.
The system senses the fan isn't working, and knows that without it, it will over-heat. So it goes into a "self-protect" mode - hence the green light.
You need to replace whatever part of your fan has gone bad.
Ryan
Franklin, IN.
MusicManRyan@hotmail.com
Jun 06, 2009 | Audio Players & Recorders
Fuse # 7 (Fan)
4cyl or 6cyl engine? Have the cooling fan switch checked. It is supposed to go on when certain temp is reached, but it apparently isn't functioning properly if it isn't turning the fan off when the temp drops.
Oct 24, 2008 | 2006 Dodge Stratus
Techwood home theater remote code model #plr85
Feb 27, 2008 | Audio Players & Recorders
I have a Techwood PLR85 spearkers will not play, have replaced bus fuses 6v&7v fuses keep blowing out and still nothing
Feb 20, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
