Question about Dell HP-P2507FW Power Supply ** FREE DELIVERY ** (HPP2507FW300WB) Power Supply
Pulsating hard drive on startup and off
Dell Dimension 4600 OS=XP Pro
When powering up the computer, the hard drive pulsates and the LEDs flash. I have to hold the start button in, and it will finally start.
When shuting down the computer, sometimes the hard drive will pulsate, and again I have to hold in the start button to shut down.
Any ideas?
To eliminate a software problem, I installed another hard drive with the same operating system, and the problem still existed.
I also flashed the BIOS with no results.
The most logical conclusion is that the problem lays with power supply.
A new power supply was ordered today.
Posted on Jan 14, 2009
We reinstalled the XP OS for a Dell Dimension 4600 and now it doesn't recognize the Network Interface Card. Any suggestions?
If you have another computer available go to dells's website and download the drivers for this model to a cd or flash then take it to the 4600 and go to device manager if a network card is available right click and go to properties then update the driver directing it to the cd or flash that you just made....
Jul 06, 2010 | Dell Dimension 4600 PC Desktop
My dell dimension 4600 asks me if I want to open in windows xp upon bootup. Windows xp is the only operating system on my computer. I suspect I have to change a setting somewhere but do not know where....
Hi! You can try this step: Right click on my computer->properties->advance tab, click startup and recovery settings->under startup and recovery settings there is a edit box, click edit then you will see a text doc that refers to the operating system installed.
-you need to delete ONLY the second one that is listed there.highlight the second one and then delete it.save the file and then check if this works
-if this works then you dont have to choose 2 operating system again during startup.
May 25, 2010 | Dell Dimension 4600 PC Desktop
I closed my business last month and my desk top dell dimension was networked with microsoft xp pro and i want to take the hard drive from that somputer and install it in my home computer which is a stand...
HI,
When you remove the harddrive from a computer and plug it into a different machine though of the same model.It would not boot, because the operating system product key is unique to the machine. If you want to use this particular hdd in your home system, make it a secondary harddrive or reload windows on the harddrive again. But doing so , you would remove everything from the harddrive.
Thanks for using Fixya
Proton
Nov 07, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimension XPS PC Desktop won't boot
Vista is available in 32 and 64 bit os.
if your system ran xp which was most likely 32 bit. And you have installed a 64 bit version os.
this will be your problem, also Vista requires more system RAM/Memory to run it.
If you get 1 beep at startup, it states the system is ok.
Alternatives are device drivers incompatability.
Check M$ website, regarding vistas minimum system requirements.
Mike @ Compurepair.
Jun 11, 2009 | Dell Dimension XPS PC Desktop
Dell Dimension 4600 stalls during boot
Turn the computer's power on.
Immediately put the original Windows XP CD into the drive.
Tell the computer to boot from the CD (not from the hard-drive).
Does it start to boot from the CD?
Do you get as far as the "repair/install" boot-screen?
If so, your basic hardware is OK, and turn your computer off,
rather than choosing "repair" or "install".
Then, it's probably either the hard-drive that is failing,
or the installed copy of Windows XP is fuddle-duddle-ucked up, so that it cannot finish the "Windows startup" processing.
Apr 23, 2009 | Dell Dimension 4600 PC Desktop
Computer not reading free agent pro
I suspect an IRQ conflict in this case. where one day things are workig fine and the next day they are not because the IRQ conflict has made it's self known.
if no IRQ conflict is present , I would suspect a dead drive , time to replace the ole girl. these things happen , touchy equipment , buggy driver sets , you name it , things will however improve.
and remember if it's not hebrew , it's a lie :-> shalom
Sep 08, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Problem with Dell 4600 Dimension Computer
on the computer you will see 4 leds labled A B C D. make sure all are Green. if not there is some issue withe the system.
Jul 04, 2008 | Dell Dimension 4600 PC Desktop
Slave drive into Dell Dimension 5100
Yes it does. It may not have an IDE cable if using SATA hard drive, but it does have a port on the motherboard to plug in the cable you take from your 4600.
Don't forget to rate your answers please!
Jun 07, 2008 | Dell Dimension 4600 PC Desktop
Installing XP on a dell computer
try to go to bios and load bios defaults, esc then save and exit. boot from the cdrom by, tapping on F12 at dell screen. at boot menu screen, choose cdrom, press enter, when you see the message, PRESS ANY KEY T5O BOOT TO CDROM, hit any immediately, that should allow you to install xp directly from the cdrom.
Feb 13, 2008 | Dell Dimension 4600 PC Desktop
Hard drive and cd drives still on
Locate Power Wakeup option in modem/LAN in BIOS and disable them, if you have "power wake up" enable for LAN/modem your computer will be switched on for remote network command.power wake up setting are located on BIOS.
Dec 09, 2007 | Dell Dimension 4600 PC Desktop
Dell HP-P2507FW Power Supply ** FREE DELIVERY ** (HPP2507FW300WB) Power Supply Logo
225 people viewed this question
Alun Cox
