Question about NADY SRA-2150
How to connect a microphone to a Nady SRA 2150?
Using a Shure SM 58-CN mic with XLR connects
    Prodigy:
    An expert who has answered 500 questions.
  • 611 Answers
Contact Nady. They should be able to tell you how to connect the mic to their system.
Posted on Feb 01, 2013
No sound
1st thing to try is a different XLR microphone cable. Sounds too simple, but sometimes it's the cable. If the mic has ever been dropped/damaged, OR has seen alot of saliva/spit from singing into it...it's possible the diaphragm has crapped out. At which point, get a new mic, because the SM-48 is not an expensive mic to replace with same.
Jan 06, 2013 | Shure SM48 Professional Microphone
Looked on 5 sites- inconclusive answers- sm 58 mic three posts on voice coil/ diaphragm, three wires leading to it. low imp use- connect which colors to which terminals? james
Try this.... Search google for: shure sm58 wiring diagram
In one of the results you will find diagram and colors in the upper left corner pix. If yours doesn't have those colors, congratulations, you have one of the counterfeit Shure mics that are being sold.
Jul 26, 2011 | Shure SM58 Professional Microphone
Neumann TLM mic is inoperative when connected to PA with same cable that worked with Shure SM 58 mic
The Shure SM58 is a dynamic microphone instead of the electret one Neumann TLM 103. This means that Shure does not need a phantom power supply voltage, instead of Neumann TLM 103; this one needs 48Volts. Here are the specifications for each one of the microphones: Shure SM 58 - Neumann TLM 103. In case you use a pre-amplifier or an audio console try to locate a switch marked as "Phantom Power" and turn it on. Typically there is no problem supplying a phantom power at the SM58. In case you have no phantom power switch available, either post back the mixer brand / model to check it for you, or post me a question to suggest you one. Details about the usage and the mixer you are already using will help me to clarify the total audio situation.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jan 27, 2011 | Neumann TLM 103 Professional Microphone
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
Shure 58 when plug it has no sound
First i would check the cable. If cable seems good I would buy some contact cleaner and try cleaning the xlr pins on the bottom of the mic. Last i would take the set screw out of the side of the mic and carefully remove the xlr assembly. There are 2 wires connected to that and not a whole lot of slack so be careful. Basically make sure they are still soldered on.
Mar 27, 2010 | Shure Beta 58 Microphone
Hi i need to know the color code to assemble a new 3 prong stereo 1/4 inch jack for a shure sm 58 microphone. i need to know the order and color to reassemble the mic cable to a new 1/4 inch guitar type...
Unfortunately, different cables use different colors of wires. Thus, you'll have to see what colors are connect to both ends of the cables. Here is the wiring:
XLR -> 1/4 inch
Pin 1 -> Sleeve
Pin 2 -> Tip
Pin 3 -> Sleeve
Dec 24, 2009 | Audio Players & Recorders
Where can i get my shure beta 58 repaired? I live in Redditch in the UK.
The easiest way to find a service agent near you for your microphone is to contact Shure at the following;
All service and repair issues for Shure, QSC, Phonic, Sound Devices and Radial products are handled directly by Shure Distribution UK. Please contact them at the following for information on service and repair issues:
Unit 2
The I.O. Centre
Lea Road
Waltham Abbey
EN91AS
Phone: 44(0) 1992 703058
Fax: 44(0) 1992 703057
email service@shuredistribution.co.uk
Hope this helps. Please remember to rate my answer.
Many Thanks
Jul 13, 2009 | Shure Beta 58A Professional Microphone
Shure beta 58
Benimur, you are correct, except that the Beta 58 is a condenser mic that required phantom power. In that case all 3 lines are used. Included below are the connections.
Dan
Sep 11, 2008 | Shure Beta 58A Professional Microphone
Vt 2008 mic
The V-Tech mic is actually a clone of the Shure SM-58. There's some discussion about how it is actually made (since V-Tech has no information on their website about their microphone line), but it looks to be made out of aluminum, vs. Shure's Zinc alloy. I believe it will sound the same, it just won't be as rugged as the SM-58.
(I know people who have used an old SM-58 as a hammer to pound stakes for their remote tent into the ground - and it still functioned afterward).
Nov 17, 2007 | Vtech VT-2010 Microphone
NADY SRA-2150 Logo
80 people viewed this question
Top NADY Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NADY Audio Player and Recorder Expert? Answer questions, earn points and help others
