Question about Royal Sovereign Office Equipment & Supplies
Have a Royal Sovereign AFS-800BK paper shredder. We had to take the top off to clean out some stuck shredding, and now the check cover/safety cover light will not go out
fellowesrep
  • 102 Answers
SOURCE: shredder problems
Seems it could be a problem with one of your sensors Fellowes Customer Service can easily and quickly diagnose your problem. 1-800-945-4545
Posted on Feb 26, 2008
geemarie
  • 876 Answers
SOURCE: SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Posted on Aug 01, 2008
SOURCE: Need part for royal shredder model sc800
Here's what I found, but good luck...... I've been on hold for 20 minutes now....
http://www.royalsupplies.com/contact-us.html
Spare Parts: 800-222-2310
Posted on Mar 21, 2009
SOURCE: paper shredder not working
perhaps the basket is not in properly. This has happened to me.....
Posted on Apr 04, 2009
  • 8 Answers
SOURCE: Shredder motor runs but gears are not engaging and
I have the same problem and upon removing the gears I found one that is plastic and worn pretty bad. Replacement parts can be purchased at 1-800-222-2310. Part # VF1012MX-08 Gear #2
I advise purchasing the metal one.
Posted on Aug 08, 2009
How do I remove paper stuck in my shredder????I have a Royal 10X Cut Paper Shredder. On label it has PCUA:29054E 10x 00324040. How do I take it apart to remove the wedged paper???
You may have to turn it upside down and go to work with tweezers and a utility knife to remove every bit of paper from the mechanism. I have found that 10X rating to be overly optimistic; the equivalent Royal shredder I am using currently groans and complains if more than a few sheets are fed in at a time.
Feb 22, 2015 | Royal Office Equipment & Supplies
How do you remove the top to see the gears in a Royal 16CDX cross cut paper shredder. The overload message is displayed, and I don't know how to get it unjammed.
a possible solution is to UNPLUG the unit, reach in from underneath and start pulling stuck paper out. On mine (different model) I can remover the paper receptacle bin and reach up to remove stuck paper. this usually is caused by overloaded bin pushing shredded paper back up to cutters because it is overfull......BE SURE TO UNPLUG FIRST !!!!!
Nov 17, 2012 | Royal 160MX Also called 16CDX Cross-Cut...
I've lost the manual what is the maintenance on the VF 1700mx
Shredders need no "real" maintenance......if you can open the top cover once per year and clean out any debris that might build up inside...other than that just occassionaly put some shredder oil onto a sheet of the paper you are shredding to help in lubrication/cleaning of the cutting teeth of any builld-up of dust and debris that take place during the shredding process.
Jul 18, 2011 | Royal VF1700MX Shredder
I have a Royal CX 66 Crosscut shredder and attempted to shred 10 pages. The unit shredded 1/2 of the papers and the other 1/2 are stuck in the shredder; the reverse mode will not release the papers. Is...
The Royal cx-6 shredder is a small consumer shredder rated for "up to 6 sheets at a time" so yes it will jam with anything more that 6.
If running it in reverse won't work you will have to try to open it up and see if you can manually turn things to get the paper back out...there is no other way if it wont run in reverse...hopefully when you have the paper removed the machine will still function.
Oct 27, 2010 | Royal CX6 CrossCut Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
I have a Royal RL170MX shredder. It has started
Try putting some oil on a sheet of paper and then shredding the paper with oil on it.
If that dosn't fix it....take cover off....(with the unit unplugged.) and check plastic gears in drive train.
May 20, 2010 | Royal RL170MX Shredder
Shredder motor runs but won't shred paper. No
If the motor is running do the cutting shafts turn??? if not then unplug and open up the top to see if any gears are broken/stripped; give Royal a call at 1-800-524-0799 for parts and prices once you've located the problem.
Oct 23, 2009 | Royal VF1000MX Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Royal VF 1000, overloads with one sheet of paper
Try pouring some shredder oil into the cutting blades where you insert the paper then run the unit in reverse for a while. Then put some of the shredder oil onto a sheet of paper and try shredding the sheet of paper. Some lubrication on a x-cut shredder does not hurt.
Jul 21, 2009 | Royal Office Equipment & Supplies
60 people viewed this question
Top Royal Sovereign Office Equipment & Supplies Experts
wrath201
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Royal Sovereign Office Equipment and Supply Expert? Answer questions, earn points and help others
