Question about Fahrenheat FBE15002 Baseboard Heater
There is a black "soot" coming from my radiant heater
It goes up the walls above where the heaters are installed and on the windowes and curtains, and this "black soot" is not easy to clean or wash out of fabrics. There were new heaters when i moved into my condo 4 years ago and i am constantly repainting my walls because i cannot wash or remove this "black soot". What would cause thsi broblem
  • 3 Answers
Black soot appearing above and around electric baseboard heaters is caused by burnt hydrocarbons in the air.
The Heating element draws the cool room air from the bottom and over the element. Any excess hydrocarbons in the air become burned and are deposited on the surrounding surfaces from the warm heated air flowing up out of the heater.
The Heater is not the cause of these hydrocarbons. They come from the home / enviornment.
Some cause.
Smoking, burning Candles releases waxy hydrocarbons, carpet cleaning solutions, spray type air fresheners.
Black waxy sooty deposits are usually from burning candles.
Posted by George Patterson
Posted on Oct 07, 2009
I have base board heating and I have notice black soot on wall and doors. What can I do to prevent this problem.
Posted on Aug 10, 2009
Soot on walls
Posted on Sep 12, 2009
Our Rinnai gasheater is in 'n working condition but since we used it the white walls and ceilings are covered with black marks - I am worried that it could be dangerous - any advice?
Unfortunately, you failed to mention the Model Number and whether its a flue-less or Vented unit. In either case, the black streaks you see on the walls and ceilings is soot. If it's a flue-less unit, this is an indication that the unit has not received routine maintenance on a regular basis. The sooting is caused by a dirty or clogged burner or low gas pressure.
Also, burning scented candles and operating the heater at the same time, will cause soot. Not from the heater, but from the candles. All candles soot, but scented candles soot more than others. Combine them with the warm moist heat and they will soot 50 times worse. If this is the case, it's the candles sooting, not the heater. Stop burning the candles while the heater is in operation.
Is the soot dangerous? Yes, to the point that you are breathing it in, when it;s floating in the air. The sooting didn't occur over night, it has been doing it for sometime. You finally realized it, when you saw the black streaks. Stop using the heater until it is professionally serviced by and authorized Rinnai Service Technician and the walls and ceiling are cleaned.
You can either remove the soot yourself or have it professionally done. Then, you should prime paint the walls and ceiling with a sealer like Kilz, before repainting. All curtains or draperies should be washed or dry cleaned. All furniture and carpeting should be vacuumed thoroughly.
I hope this helped you and thanks for choosing FixYa.
Aug 10, 2011 | Heating & Cooling
Creating soot in house
Sooting is general caused by incomplete combustion. Which, most of the time is caused by a dust, lint and/or pet hair build up in the heater. It clogs the burners , as well as the air intakes. Thoroughly cleaning the interior of the heater and it's inner workings will generally solve the problem. Also, an less frequent ... low gas pressure to the heater can cause sooting. Burning scented candles while the heater is in operation contributes greatly to the soot problem and indoor air pollution.
The above should help you to further troubleshoot and solve the soot problem.
Apr 26, 2011 | Williams (5009622) Ceramic Gas Wall...
Night store heaters creating soot.
Hi soot is incomplete combustion , so there could be something on the elements causing this to burn off soot google the heater there are some things on the web about this , hope this helps
Feb 11, 2010 | Cozy (W352E) Heater
Fire and Heaters producing soot.
no its not gas it sounds like fumes get them checked over asap the localgas company will check them out for you
Jan 10, 2010 | Cozy (W352E) Heater
There is black soot on my walls and ceilings above my baseboard heaters. Is there a solution or a reason as to why this is happening? Is there a part that needs replacing? We are desperate for a solution....
In my experience soot in the house is (almost) always caused by the burning of candles. Get a CO detector if you don't already have one! You see the soot at the heaters because of the air flow they cause. There is nothing in a baseboard unit that could cause soot. Just water.
Mar 30, 2009 | Fahrenheat Electric Convector Baseboard...
I have black soot on my walls from my baseboard heaters, is this hazardous or dangerous to my health?
same issue years ago. these heaters draw air in from the bottom and push it out the top. so any dirty air (candles burning will do it) is pulled through the heater and pushed out the top causing stains on walls.
Jan 01, 2009 | Fahrenheat Electric Convector Baseboard...
Soot coming from Wall Heater
The fuel mix it too rich. There should be a place where the gas hose goes into the burner part, and an adjustment where you can adjust how much air it gets. The flame should be almost 100% blue. It can make the grates glow another color, but the flame should be mostly blue.
Dec 22, 2008 | Empire Heating & Cooling
Soot on walls
does your mom burn candles? lots of candles use chemicals for scents and they can deposit soot.
Oct 26, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Natural gas heater
The burners are shot. The heavy metal tubes with the holes that the burner flame comes out of, has burnt through. Instead of little rows of holes, there is at least one large hole in it. Unless someone has changed the gas>air mixture, you need new burners.
Mar 13, 2008 | Empire DV-215 Direct Vent Natural Gas...
Fahrenheat FBE15002 Baseboard Heater Logo
2,636 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
