Question about Ricoh Aficio CL-7100 Type P Staple 5K
Error code sc 221-3 - Ricoh Aficio CL-7100 Type P Staple 5K
  • 30 Answers
Subcode 3 point to Cyan
After doing any of the following, print
ten jobs or more to see if the same SC
code is displayed:
1. Turn the main switch off and on.
2. Check or replace the cable
connecting front (for C&M) or rear
(for K&Y) synchronizing detector
board and the LD unit.
3. Check or reinstall the front (for C&M)
or rear (for K&Y) synchronizing
detector board.
4. Replace the front (for C&M) or rear
board.
5. Replace the laser optics housing
unit.
6. Replace the BCU.
If a synch. detector board cannot be
replaced, do the following as a
temporary measure:
• Disable main scan length detection
(SP 2-919-001)
Posted on Mar 07, 2014
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
How can I fix the error c6400 on kyocera taskalfa 221?
Hi
I found this explanation of your error, although my understanding of it is not entirely clear.
Code: C6400
Description: Zero-cross signal error
Interrupt of the zero-cross signal does not occur more than 1 s.
Causes: Poor contact in the connector terminals.
Defective power source PWB.
Defective engine PWB
You can find this here:
Error Codes Kyocera Mita TASKalfa 221 Code C6400
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 17, 2014 | Kyocera Office Equipment & Supplies
Code erreure sc 300 aficio mp 6000
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Jan 17, 2012 | Ricoh Aficio 120 Copier
Copier error code 221
We are assuming that you are talking about Error Code SC 221
This code is a Scan length detection problem.
1.Disconnected Sychronization Detector
2.Bad LD-Unit/BICU Board
SOLUTION: Replace the Laser Diode & Laser Sync detect board
Hope helps (remember to rating this free answer).
Oct 12, 2011 | Ricoh Aficio 1232C Color Copier
Ricoh 6513 Error Code Sc.387 Error Code Sc.457 Error Code Sc.350
1. Set SP3-125-003 to a value of
2 to enable Job End & Non-use
3 Self Check Mode.
fore more hrlp visit https://cbrtechsolutions.net
Jan 21, 2011 | Ricoh 6513 Copier
Hello! I'm writing from Romania - East Europe. A Ricoh Aficio 3224c not work at all. Error code SC 221 appears on the screen in a few seconds after the device is turned on. What to do? Thank you! J. Coman
please check with your head cleaning and also your ink cartridges. if low replace and reset. If fault is still on, then reinstall the printer software and restart. . Please also check on your connection cords. See if any paper is jammed or is obstructing the mechanism, check carefully. i hope you get this fault. good day
Jul 14, 2010 | Office Equipment & Supplies
I KEEP GETTING AN ERROR ON MY RICOH CL 7000 THE ERROR READS SC 221-2
SC No. Item Definition Possible Cause Related
SCs Troubleshooting Procedure Type
SC 221 Synch.
detection signal
error 2
221-001: Y
221-002: M
221-003: C
221-004: K
Main scan length detection is
not properly completed ten
consecutive times.
The front (for C&M) or rear (for
K&Y) laser synchronizing
detector boards are used for
the main scan length
detection, which automatically
corrects the main-scan
magnification.
• Damaged or
disconnected cable
between front (C&M)
or rear (K&Y) laser
synchronizing
detector board and
the LD unit
• Incorrect installation
of front (C&M) or rear
(K&Y) synchronizing
detector board (the
beam does not target
the photo detector.)
• Defective front (C&M)
or rear (K&Y)
synchronizing
detector board
• Defective LD unit
After doing any of the following, print ten
jobs or more to see if the same SC code
is displayed:
connecting front (for C&M) or rear (for
K&Y) synchronizing detector board
and the LD unit.
detector board.
board.
5. Replace the laser optics housing unit.
6. Replace the BCU.
temporary measure:
Sep 15, 2009 | Ricoh Aficio CL7000 Laser Printer
Sony UVW-1800 Error Code
I just found this post on another site :
tsvservice- 29th Jun 2007 14:0109-221 is "failure to complete threading within the specified time". in plain talk, the mechanism in the deck that threads the tape around the heads is not working. this could be a bad motor, bad gear, or even a bad tape.
Feb 15, 2009 | Fuji M321SP Betacam Tape
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
Ricoh Aficio CL-7100 Type P Staple 5K Logo
119 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
