Question about Panasonic Televison & Video
Panasonic projection tv pt 53 wx 42 f wont turn on and blinks red continuously?
T.v. will not turn on at all. it will however blink red light forever. what is the problem please?
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
3 blinks or 5 blinks and pause are most common on this set---try to watch and count the blinks and let me know which you find
Posted on Dec 12, 2012
Slinteriors
  • 8617 Answers
SOURCE: power up
is it a constant blink, or does it blink a nummber of times in between payses? Let me know the number of blinks. Please respond to this same post so I have access to previously posted info.
Posted on Jul 01, 2008
asnowman
  • 788 Answers
SOURCE: I have a Panasonic PT-56tw53 projection tv and the
Your symptoms sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
What happens in the Panasonic set is that the convergence IC’s will short and cause the power supply to shut down from the overload of current. Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Aug 16, 2009
Slinteriors
  • 8617 Answers
SOURCE: my panasonic pt53wx53g tv wont turn on. the power light blinks 3
thats the error for the convergence failure. You can get the repair kit for your model at www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions
Posted on Sep 11, 2009
SOURCE: What are the error codes for a Panasonic PT-47WX 42 TV
Hello I have a Panasonic PT47WX53G and when I turn it on the red led (Power) comes on and then blinks 5 times, then it turns Off. After a few seconds the red led turns on again blinking 5 times. This cycle repeats until I unplug the TV.
Thank You Willie
Posted on Jun 01, 2010
Slinteriors
  • 8617 Answers
SOURCE: Hello, I have a 53-inch Panasonic PT-53WX42F TV,
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Posted on Jul 17, 2010
Why is my panasonic hdtv 1080i on off switch blinking red
thats usually an error code. How many times does the light blink?
Apr 02, 2013 | Panasonic PT-53WX53 53" Rear Projection...
Keeps turning off and red light is blinking 3 time
If it is Panasonic PT-53WX54 rear projection tv then 3 times red light blinking indicates problem of convergence output chips failure in tv that need to be replaced to solve its problem.
Let me know if you are handy with electronics stuff repair and can replace/ solder parts in circuit board to provide you more helpful info OR call local tv repairman to replace convergence output chips tin tv.
Thanks.
Dec 30, 2010 | Panasonic PT-53WX54 53" Rear Projection...
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
TV turns itself off after being on a few seconds, ...
Three time blink means tv got problem in convergence output circuit, replace convergence output ICs to solve the issue.
Thanks.
May 21, 2010 | Panasonic PT-53WX54 53" Rear Projection...
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Wont work
3 blinks is convergence error.
Apr 13, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-56WX33/red light blinks 3 times ovr-n-ovr
It's one of two things, a bad chipset, or bad lamp. 200-250 repair. Hope this helps
Jul 07, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Red light blinks 5 times!!
C509 .47uF Mylar 250Volt. Replace this cap, this should restore power.
Jun 04, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Tv trouble
djbone30, you need two STK392-110 convergence amplifiers.
Sep 25, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic pt-53wx54 53inc
Circuit problems, -- consult pro/tech
Apr 21, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
