Question about Vector VEC 024 400-Watt Power Inverter (VEC 024) 400-Watt Power Supply
I think my inverter burned.
I have a vector inverter 1500 watt and it may have been burned. I heard there came smoke out. Can it still be fixed or do i have to buy a new one.
    New Friend:
  • 3 Answers
First you should check the power output,what is the power output?
if there no power output? that means your power transistor is burnt.
Posted on Apr 29, 2013
    Guru:
  • 290 Answers
It depends on what burnt in it, you should check it out to know
Posted on Feb 27, 2010
Manual for black and decker 1200 watt invertor
some idea for inverter, collect inverter circuit Books from market.
May 28, 2012 | Black & Decker Vector Cable Kit for 1200...
Does the Vector Power Inverter VEC040 have an internal fan?
No they do not have any internal cooling devices. they rely on ventilation alone.
I will suggest that you read up on reviews for this item if you are thinking of buying one.
They have not gotten great reviews.
May 04, 2011 | Vector VEC040 70-Watt Power Inverter 40
I have a power on board 500 watt inverter. I hooked it up for only the second time making sure it was red to red and black to black.( i have hooked up hundreds of batteries) I turned it on to hear a pop...
Allot of these units have an internal fuse that protects them.Open up the inverter box and locate the fuse and replace it.If this does not work the diode may have blown.You can also replace this if you are pretty good with a soldering iron.
Oct 19, 2010 | Vector 2000w Power Inverter
Plugged it into the recepticle in my2009 trailblazer, and it started smoking. removed it quickly
Hello Dusty,
Sounds like your inverter was already having issues. Otherwise, the power port in your trailblazer is wired backwards (center contact should be positive, barrel or ring should be negative).
Aug 26, 2010 | Inverter Vector Power - 70 Watt, Model...
Vector 3000 watt model VEC051D
Time for a new inverter. Lesson learnt I dare say.
Check polarity!
Sep 05, 2017 | Vector 3000w
How to fix
If you are lucky, you may have blown the fuse. It is located on the back panel, usually in a little plastic slide out holder, but it can be sometimes found in a tubular container which has a knurled plastic cap.
Mar 19, 2010 | Vector 2000w Power Inverter
I have a vector 3000 watt inveter red fault light is on, wont power a 6.5 amp fuel pump
Check that ground is correctly connected. If nuetral is provided, ensure it too is connected. Your total load is 780 watts. Check power in and ground out of the supply side. There may be a fuse in the inverter on the output side also, replace if necessary. If fault light does not go out after these checks, you will need to contact Black and Decker who manufactures the vector series now.
Jan 16, 2010 | Vector Power Inverter - 3000 Watt
No led red or green vec550pob 1500 watt, nor do i know what the "power supply accessory socket"
how to repair power maxx inverter 1500 wats vec550pob
my inverter turns on but red and green light on at the same time, and fans working for 3 seconds on and off
Oct 25, 2009 | Vector Maxx SST Power Inverter
Puff of smoke
Have you looked at the fuses within? I have two in the one I am trying to fix!!
Peter
Nov 19, 2008 | Vector VEC056 MAXX Power Inverter
Vector VEC 024 400-Watt Power Inverter (VEC 024) 400-Watt Power Supply Logo
389 people viewed this question
Top Vector Computers & Internet Experts
janman
Tom Chichester
Are you a Vector Computer and Internet Expert? Answer questions, earn points and help others
