Question about Sony KF-55E200A TV Lamp with Housing
My sony KF 55E200A projection tv is loosing its colors what can be done to cure it ...plz help.
Blue and green colors time to time get in excess on sceen
    Top Expert:
  • Sony Master
  • 14,553 Answers
I need to know if areas of the screen are green or blue with the color set to zero or with the set on a unused video input with nothing connected is the screen a uniform grey or black? This will point to what kind of trouble you have.
Posted on Dec 12, 2012
  • 48 Answers
SOURCE: Sony KF-50WE610 LCD projection TV. no picture but flashing green
Replace the lamp as they dont last for long
Posted on Feb 01, 2008
ladywinn
  • 5138 Answers
SOURCE: My Sony Wega rear projection TV has green
I hate to tell you this but if your light enginge /optical block is bad you are Looking at just for Part $1,949.95 core refund is $1,300.00 Then part is 649.95 Encompass Parts Distrubtion has 23 of them
1-800-638-3328 Chances are it is your Light Engine!
Posted on Dec 29, 2009
welcomejee
  • 10594 Answers
SOURCE: color on tv are off green red blue as if it was three D. HELP!!!!
Yes, its problem of convergence out chips failure, replace two big black convergence out chips in TV to fix the problem.
If you are handy with electronics stuff repair and can replace parts in circuit board with proper tools then you can fix this TV issue by yourself or ask local tech to repair it.
Thanks.
Posted on Jan 15, 2010
milkburp
  • 416 Answers
SOURCE: Sony LCD TV
Your blue LCD panel has gasped it's final breathe. Unfortunately, this is not something that can be repaired at a component level in the field. Your TV requires the Optical Block Assembly to be replaced in order to restore it to it's former glory. HOWEVER, due to the part cost, labor fees, and age of this model... you should spend this money on a new TV and put the balance of the unspent money back in to your pocket... this repair would be too costly to pursue. :(
Posted on Mar 13, 2010
ladywinn
  • 5138 Answers
SOURCE: Sony KF-55E200A Projection TV turns on with sound
Replace Ballast board it is what powers Lamp on.
Encompass Parts 1-800-638-3328
Posted on Feb 14, 2011
Kf 55e200a
if its a dlp check the light engine there is a color wheel inside it may be worn out hence stuck and needs replacement do check that the fans are all working if one is not replce it to cos these r the only moving parts
Jul 15, 2013 | Televison & Video
Sony KF 55E200A problem picture dark and colour dominan green?
go to picture setting and change the color and change brightness or contrast
Jul 15, 2011 | Televison & Video
My LCD projection tv(KF-50E200A) displays projection lamp week when switched ON and out of red color display on the screen. Is this will happen if the projection lamp is week?
no and yes
the lamp warning is to alert you that a timer has expired that clocks the approximated life of the lamp in "hours of use".
it is never accurate and is dependent on whether or not it was reset the last time a lamp was replaced.
reset the lamp timer in the users "setup" menu.
the lamp has NOTHING to do with color, it only provides light.
check the connections between the TV and cable/satelite box...the red.green.blue component connector...the red one is likely loose.
if this does not correct you color problem, your optical engine has failed.
very expensive repair, not for the DIY type guy.
Apr 17, 2011 | Sony KF42E200 TV
I have a sony bravia 55 inch rear projection tv. model no. KF-55E200A. when i turn it on it flashes green like normal but then starts flashing red. can you tell me what is wrong with it please
Most probably it is an optical block issue. You can contact sony customer service to setup the free service.. If you need the contact infomation, please let me know where you're.
www.fixya.com/users/shajanrs
Jan 15, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have the Sony KF-50WE620 projection tv, its 2004 model and suddenly doesn't work anymore. When I turn the tv on, the light steadily blinks green and there is a strange shattering/windchimey sound that...
it could be the lamp but it might also be what is called the color wheel.. have you checked the lamp .,, have you removed and physically looked at the lamp. also does the light blink after shutdown.
Oct 13, 2010 | Sony Grand WEGA KF-50WE620 Television
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Bad picture
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
http://splinke.googlepages.com/sonyrearprojectionlcdtv-opticalblock
Jan 19, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony TV Screen
Is you model listed below?
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KF-42WE610
Sound but no picture, tv will not turn off. Light goes red but a dim overall blue screen remains and fan is still running.
Nov 15, 2007 | Sony XL-2100U Projector Lamp for...
Sony KF-50WE610
the color drive is going bad check with the sony service center it might be cover and repaired free.  my set went blue and the service tech is checking if it is covered.  good luck.
Sep 30, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KF-55E200A TV Lamp with Housing Logo
91 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
