Question about Disney Netpal by ASUS Princess Netbook
Wireless connections It says its connected to wireless but will not let me connect to Internet. It keeps wanting to run off a modem and router
  • 2,878 Answers
A little unclear, but make sure the wireless adapter are in Device Manager, by right clicking My Computer. It should be listed there without any warnings.
Then check Network Connections, in Control Panel for wireless device. Make sure it is enabled. The description varies with OS, but are similar.
Posted on Dec 12, 2012
  • Sharon Floyd Dec 12, 2012
    It is Windows XP, I have no clue why it says it is connected to wireless but when II click on Internet explorer it says the page cant be displayed. When I check network connections it is trying to connect as if I am using a modem and router instead of wireless.
Did pc system restore and lost internet connectivity to router. can connect thru modem. have wireless internet connectivity on laptop. want to reconnect internet to pc without losing wireless to laptop.
run this on your laptop - it should yield the wireless key necessary to connect to your network again.
http://www.nirsoft.net/utils/wirelesskeyview.zip
Sep 17, 2011 | NetGear WGR614 Wireless Router
Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Aug 23, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
I have a netopia wireless router, I've just had comcast install the internet however I would like to install the router. the modem to my computer accommodate only one ehternet cable at a time and it...
You can connect your computer to Internet if you have a Wi-Fi card in the computer. You need to connect the modem ethernet cable to the netopia wireless router and then connect to internet through wireless connection. First task is to configure wireless network connectivity on your netopia router connecting the 1st ethernet port to your pc lan card port, you will need the netopia instruction manual for this. The wireless configuration will be through a browser window(like internet explorer/mozilla firefox). This may take roughly 20 -30 minutes.
Jul 25, 2009 | Computers & Internet
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
My Belkin F5D8053 is working in low strength
If you're encountering a very internet connection on your router, this is can be a problem with either the internet connection from your modem or the firmware of the router should be updated, first thing that you can try is to update the firmware of the firmware of the router, you can download the latest firmware of it from Belkin web site then after that observe the connection if you still have a slow internet using the router , Try to check now the internet from your modem by connecting a computer directly to your modem and if you still have the same problem internet connection from your ISP is the problem so you can contact them about that..........
Nov 11, 2008 | Belkin Wireless-N Wireless Router with...
Modem vs. Router
Oh I thought you wanted a wireless anywhere modem.
Ok
A Modem is what you need to get the internet from your internet provider. A router splits that connection from the modem so that more than 1 computer can get on.
What you need to do is get a wireless router such as the Linksys WRT54G then connect it to the modem so that it will broadcast wireless to your laptop.
Jul 28, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Dynes Wireless G Router
Try turning everything off, PC, Router, and Modem. Then turn on the modem, then the router, then the pc. Your modem needn to connect, then the router will be assigned an ip address, then your pc will acquire an ip from the router.
Jan 14, 2008 | Computers & Internet
Wireless configuration
What you will need: Wireless router and a wireless adapter connected to your PC. This is assuming you have a broadband internet connection. Install the wireless router by taking the ethernet cable out of the back of your computer and placing it in the WAN or internet port in the back of your router. Install the wireless adapter inside your PC. Unplug your modem for a minute or so. Then plug in your modem and your router, then turn on your PC. If you are running XP, it should see a list of wireless access points you can access. Select the one for your router (should be the strongest) and hit connect. This will connect you to the wireless router and the internet. Note this solution assumes the following: You have a high speed internet connection, your ISP's modem is connected to your computer via an ethernet cable, and you are running windows XP.
May 19, 2007 | RCA DCW615R Wireless/Cable Modem
Disney Netpal by ASUS Princess Netbook Logo
Top Disney Computers & Internet Experts
David Payne
David Payne
Are you a Disney Computer and Internet Expert? Answer questions, earn points and help others
