Argus 500 slide projector model 58
I' m looking for a manual for this projector, or repair guide.
hmerchant110
  • 7191 Answers
SOURCE: I am looking for a user guide/manual for an Elmo
You can download the required manual from: http://elmousa.com/files/archives/TRV-35H/TRV-35H.pdf
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Posted on Sep 01, 2009
Testimonial: "Thank you for the quick response. I'm also looking for a remote for the equipment. "
  • 412 Answers
SOURCE: Just purchased a Kodak Ektagraphic AF1 &
The model AF-1 did not have remote focus feature. It does have the Auto-Focus feature. The auto-focus adjustment is a pretty "fine-tune" adjustment that requires a factory alignment tool & a trained hand.
Your model AF is quite old, and probably requires replacement of the "link" that connects the slide change solenoid to the slide change mechanism. The problem is the plastic the "link" was made of gets brittle over the years and cracks, rendering slide change non-functional.
Both problems are easily remedied by a qualified repair dealer with the tools, training and parts.
Posted on Nov 03, 2010
  • 412 Answers
SOURCE: Model 760 H projector-- Carrousel advances, but slides do not
My guess is that your slides are in a 140-slide tray.
Over time, with repeated cycles of humidity & drying, slides warp slightly. The compartment width in a 140-slide tray is quite narrow, and it takes very little warping to make slides stick in their individual compartments. If you move the slides to a KODAK 80 Slide Tray you should be in much better shape.
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: model 750H overheated and guide says
That is correct. There are 2 thermal fuses: 1 near the lamp, 1 on the power motor. This repair should be made by a factory-trained tech.
  • 412 Answers
SOURCE: Automatic slide changer is stuck in
The problem is continuous cycle (like you don't know that already...). It indicates that an adjustment to the cycle contact is necessary. To open the projector, first unplug it and remove the lamp module from the rear of the projector. Turn the projector upside down. Remove the 6 - T15 TORX screws from the bottom (5 around the perimeter and one in the channel next to the cord wrap). CAREFULLY pull the bottom off (the power wires connect the bottom cover & top together!!). Once you have it open, leave the projector upside down, put on your safety glasses & plug the projector into the wall. At the center of the projector you should see a hub rotating about every second or so. Above it you should see a "J"-shaped wire. See the attached illustration.
You will have to, in repeated steps, unplug the projector, bend the "J"-shaped wire GENTLY & SLIGHTLY, plug the projector back in and cycle it a few times. Check for the position of the "J"-shaped wire to the pad, and GENTLY repeat until you achieve the position shown in the illustration.
Posted on Dec 30, 2010
I need the owner's manual for a Sears Du-all projector
I believe if you check out the "Manuals & Guides" section of Fixya, they have the manual there. I found many listings for it online, also. Jim
Oct 09, 2012 | Sears Du-all Eight 8mm Projector...
How can I get my Gateway desktop to recognize my Projector?
it has to be set up as an additional monitor/display. so, there are settings to set up the displays as either twins, unique seperate or something like that. have not had to do it. but i know that the graphics have to be able to recognize what format the signal is. pc settings change and graphics setttings change. have you done both? the projector should have had instructions? if not look for the manual online.
Aug 23, 2012 | Gateway Computers & Internet
Kodak kodascope pageant model 1 16mm film with sound projector
Contact the Eastman House in Rochester, NY for a possible lead for a repair manual and/or a qualified repair person. I will tell you that Kodak has not had parts for Pageant Projectors in about 20 years - - - but many authorized repair dealers may still have some!!
Good Luck !! Jim
Nov 19, 2011 | Office Equipment & Supplies
I have a slide projector Kodak carousel S. The slide does not want to change! The ventilation & light work. I looked inside and it seem that there is no push from the middle of a cilinder (sorry do...
This projector was manufactured by Kodak in Stuttgart, Germany. You can check with Langie AudioVisual on East Commercial Street in East Rochester, NY. They were the last dealer I know of that still had a technician trained on the Carousel S. I don't have manuals for that model. Sorry I can't be of more help!
Sep 18, 2011 | Kodak Ektapro 7020 Slide Projector
Looking for an owner's manual for Acoustic Research 310HO loudspeaker. I would like to know the correct crossover frequencies for bi-amping.
Try
mauritron.com
They have the world's largest library of
owners user instructions operating guides
and
technical repair schematics circuits service manuals
I'm not connected to them, just a satisfied user.
Also if you don't find your item in their listing then ask and they will get it for you
Sep 17, 2011 | Acoustic Research 310 HO Speaker
My Windows XP is connected to my Epson Powerlite S3, but the screen is blue with the words Source: Computer (Auto) No Signal on it. When I click "Help" on the projector, it takes me to a screen...
'No signal' and 'unsupported signal' messages mean 1 of 2 things, either the VGA output is off(laptop) or the display resolution is set too high(laptop and desktop). Assuming the VGA cable you are using is good, try this:
Desktop: hook the computer back up too your computer monitor & set the computer to the basic VGA resolution. For windows XP, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes!
Drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector. You will need to change the settings each time you switch monitor to projector.
Laptop: by default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue button (on the lower left of the keyboard, usually to the left of control ) and tap the bleu button you just found. Let go & give you're a computer a few seconds to change over. If the laptop screen goes blank, you found the correct button! The display image should now be visible. Repeat this 1 to 2 times to change it back to laptop display.
If you did not see the display on the projector, 2 other issues are possible. First, verify that the VGA output on the laptop is working - connect the laptop to a regular computer monitor & change the display resolution to the lowest settings (see desktop above), then try it again on the projector. If you cannot get an image on a computer monitor, your laptop settings may need to be adjusted in the same dialogue box as the settings. Monitor #1 is the laptop display, Monitor #2 is the external output.
Happy viewing :)
Jun 12, 2011 | Epson PowerLite S3 Multimedia Projector
EPSON EMP TW600. Red light is flashing after it is powered on. I read the manual too quickly, and decided to change the lamp thinking that was the issue. Put the new lamp in, red light is still flashing,...
You can try to blow the fans with compressed air available in a can at most stores. Make sure the pj is unplugged as the air is flammable. Use a flashlight to locate the fans behind any vented areas around the case. If it doesn't help it may still be a fan you cannot get to or the lamp ballast may be failing to start the lamp. Also check user guide to see if there is a lamp hour reset procedure to zero the hours by pressing the menu or remote buttons in a specific order. Sometimes PJs shut down & will not restart if the lamp has gone past it's limit.
Apr 14, 2011 | Epson EMP-TW600 LCD Projector
I just purchased a Artograph DB300. I need an instruction manual even though it's seems simple enough. I've had the Super Prism and found the clarity poor. This old model seems to be sought by many. ...
8/23/11 I have an Art-O-Graph DB300 Projector along with a rolling table that it's clamped to that I am needing to sell. It is quite large & in new condition,& not familiar with. It is my fathers who is now ill & unable to use. Hoping someone can help me or guide me in how & where I can do this? I live in the Chicagoland area. Pls can anyone help? Thk you!
Dec 06, 2010 | Artograph MC250 Projector
I have a dataprojector, no signal
Then 'No signal' or 'unsupported signal' messages are usually because your display is set too high. To see if this is your issue, hoop it back up too your computer & set the computer to the basic VGA resolution. Assuming you are using windows, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes, then drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector.
Note for Laptop users-- By default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue <fn> button (on the lower left of the keyboard, usually to the left of control <crtl>) and tap the bleu button you just found. Let go & give you
Nov 14, 2009 | Toshiba TDP-S81U DLP Projector with...
308 people viewed this question
k24674
