Question about Sewing Machines
The threads are in the correct "needles", but the upper yellow one does not stitch. It goes up and down, but no stitch form on the material. Please, this is urgent.
No stitch.
  • Sewing Machines Master
  • 7,365 Answers
Try changing the needle first and see if that helps.
Posted on Dec 12, 2012
4 Suggested Answers
manski
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
SewExpress
  • 41 Answers
SOURCE: Stitches not forming!
Good Morning,
A few things to try:
  1. Loosen the needle screw, make sure the needle is fully up in the needle hole and re-tighten the screw. Vibration can sometimes cause the needle to slip...and the needle not fully inserted can cause this problem.
  2. Make sure the bobbin is turning the proper direction. If your machine has a standard bobbin case that comes out of the machine, turn the case so the bobbin is facing towards you. Pull the thread tail and make sure the bobbin turns clockwise. If it's turning counter-clockwise, flip it over and try your machine again. If your machine has a drop-in bobbin, double-check your particular machine instructions to make sure it's going the right direction (clockwise or counterclockwise depending on the machine).
  3. Make sure you have tension on the upper thread. Do this by lowering the presser foot (make sure the thread tail is NOT under the foot) and give the thread a tug. You should feel tension on the thread. If not, the thread isn't fully down in the upper tension disks. You should be able to give it a further tug to pull it down into the disks. No tension on the upper thread can cause the stitches to not form.
  4. If none of the above seems to help, you'll need to get your dealer involved (provided you purchased your machine from a sewing machine dealer). They can determine if it's just something happening during threading or if the machine is out of timing. They are there to help you before AND after the sale and should be willing to take care of whatever is happening.
  5. If you did NOT purchase your machine from a dealer, and the store you purchased from does not have a sewing machine technician, we would suggest that you return/exchange it for a new machine and see if the new machine has the same problem (most department/big box stores that carry machines have a very liberal return policy since they do not have personnel dedicated to sewing machines).
  6. If the new/replacement machine has the same issue, we would suggest you return it (no sense frustrating yourself) and perhaps find a local sewing machine dealer to purchase a machine from. Authorized sewing machine dealers are geared towards providing machines and service (before and after sale) and are worth the extra $ for the peace of mind and knowledge that you'll have someone local to call on for help.
Best of luck with your machine - we hope it's something minor and you're up and sewing soon! Don't hesitate to reply to this post if we can offer further help, ideas or suggestions.
Happy sewing,
Kim & Linnette
www.sewingexpressions.com
Posted on Jul 23, 2008
mallow1
  • 35 Answers
SOURCE: Thread tension?
I own this little gem of a machine. It definitely sews a perfect stitch. I'm assuming you own the green 3/4 size machine as denoted by your product number. The half size blue one pictured is incorrect.
Anyway, this machine sews a perfect stitch, due to the oscillating bobbin. Most sewing machines with rotary (drop in) bobbins don't have an easily accessible bobbin tension screw, which means your fabric is usually slightly puckered. Fiddling with only the upper tension helps very little. This frustrates me to no end for sewing long curtains, clothing side seams, etc. Wrong tension causes them to hang with puckers, making them look awful. With the Hello Kitty 3/4 size Janome, there is a screw on the bobbin case which allows you to adjust for every thread diameter perfectly. Always a perfect stitch, if you take the time to adjust this screw.
To adjust the bobbin for a perfect tension, load the bobbin into the bobbin case and thread it through the guide. Holding only the thread between two or three fingers, let the bobbin case dangle below. This will be slightly difficult, because the bobbin will want to fall out of the case. Don't worry, just don't move it around too much and it will stay in long enough for this test. If the metal bobbin case slowly drops lower, unwinding thread as it goes, the thread is too loose. Tighten the screw on the side of the bobbin case a little (about a quarter turn.)
If the bobbin case seems to be dangling firmly, give the thread a gentle tug, lifting up fairly quickly. If it doesn't release a couple of inches of thread, it's too tight, loosen the screw. You know the tension is perfect when a quick, light tug of the thread releases a couple of inches of thread.
Posted on Aug 16, 2008
Adjusting top and bottom stitches...
the stitch length is set by the amount the foot pulls the material through
adjusting the needle thread tension is the main adjustment to ensure that both threads meet at the center of the materials being sewn
Mar 10, 2017 | Sewing Machines
Top thread too tight. Bobbin thread too loose. Bobbin thread bunches up underneath material. The feeder teeth can not feed material through
first thing first - thread inside bobbin should be tightly wound in. Insert bobbin into bobbin case and thread through slot and under the spring. Spring has small screw which regulates the tension. Hold the thread like yo-yo and jerk a little down-up. It should drop just a little (not run down) - that is usually required bottom thread tension,
if not, regulate with the screw. Set top thread tension 3 and sew. If still looping under, increase the top tension higher till the looping disappears. .
Nov 03, 2015 | Sewing Machines
The zig zag stitch is on the bottom of the fabric instead of the top how do I fix this for a Singer sewing machine model 7015
In two words, this sounds like a problem with: thread tension. Quite possibly to the point of having an entirely mis-threaded machine, whether because the thread was not routed correctly, or because parts of the thread path are missing.
(Let's review - just for a sec - the basics of how the stitch is formed. The needle, carrying the upper thread in its eye, penetrates the material. When below the material, the needle begins traveling back upward, creating a loop in the thread. (Depending upon the type of machine, either a hook or a shuttle) then pulls this loop so that the lower/ bobbin thread runs then through it. Then, as the needle retracts further upward, an arm (between the tensioning disc/spring and the needle thread path) pulls upward of the thread, tightening the stitch into place.
If, for example, there is no tension at the tensioning disc/spring, that arm will take from the thread spool instead of tightening the stitch into place.
Dec 14, 2014 | Singer Sewing Machines
Bobbin thread wont form a stitch
Hai, Please check the bobbin tension and winding. And cleaning the machine.
Mar 20, 2014 | Brother InnovIs 4000D Computerized Sewing...
Hand held sewing machine
I think you are saying no stitch is formed also referred to as the needle not catching thread. Below offers a variety of diagnoses and solutions which are straight forward.
Sewing Machine Needle Not Catching Thread
Below is general advice quoted from 6 common sewing machine problems solved:
Skipped stitches are usually due to a bad needle. The needle may have become damaged or bent by sewing material too thick for the needle, forcing material through the feed dog, or hitting a straight pin. If the problem seems to be consistently reoccurring, it may be due to forcing the fabric. Sewers should allow the feed dog to pull the fabric and only use their hands to guide the fabric through the feed. When sewing knitted fabrics, using a stretch needle can help prevent skipped stitches.
Below is a video showing how thread is hooked into a fabric:
Sewing Machine Anatomy How Stitch is Made
Jan 18, 2018 | Sewing Machines
Sewing machine will not stitch. The thread goes into the material but does not make a stitch. I've changed the needle, cleaned the bobbin, rethread the bobbin and the top thread.??????????????
Is this the first time you have used the machine? If so you need to bring up the bobbin thread by hand before stitching. Only when both bobbin and top threads are up through the needle plate nad pulled towards the back of machine, will the machine form a stitch.
Dec 17, 2010 | Singer Confidence 7467 Mechanical Sewing...
Stitch is uneven, not straight, and tension off on top and bottom
on my industrial machine this was caused by the wrong size needle. the length was off just a fraction. just an idea, in case you bought generic needles or something.
Nov 24, 2008 | Singer 3116 Simple
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Feb 26, 2008 | Singer 2662
Sewing Machines Logo
19 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
