Question about Saeco Royal Professional Espresso Machine
Purga en saeco royal professional
En la pantalla pone purga y no se como acerlo
  • 60 Answers
SOURCE: Cappuccinatore Milk Temperature on Saeco Royal Pro Machine
Hi
First open it up and run it without any milk attached until just mostly steam is coming thru. Turn off - then drop the tube into a jug of milk which is locted below the outlet. If its steaming, the milk will be heated up ok - it may need flow adjusting - lift the thin 'plug' near the tube up and down to adjust flow. You can add to the froth by lifting the tube out of the milk for a moment then back in again a few times.
To clean the unit just run clean water tru as tho it was milk until it comes out totally clear (about 1/4 cup). For hygiene sake make sure the tube is wiped clean on the outside with a clean paper each and every time when finished.
You can flush your main coffee lines out by making out its doing a large preground coffee - but don't put any preground in.
Select preground - select large coffee and go. Pays also to remove the brew unit and wash in warm water once a week - saves coffee goo building up and causing it to stick.
Posted on Feb 22, 2009
  • 1089 Answers
SOURCE: saeco royal digital part 0701.R05.050 broke how
HI
Its called a thumbscrew. You have pulled the nut that was molded into it out. Don't use the key to install the new one. That is why they call it a thumb screw. Finger tight. Should be able to get it from one of the online vendors. http://www.partsguru.com carries it. Wholelattelove. 1st line.com
Posted on Oct 26, 2009
Testimonial: "thanks "
SOURCE: Can you reset the Saeco Royal professional back to
SSS
Posted on Feb 16, 2010
  • 1089 Answers
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Posted on Jun 14, 2010
  • 1089 Answers
SOURCE: Hello , I got a present
Hi
Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to "Descale". Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process simply turn the steam knob. When the process is over your machine will say "descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and close the steam knob then open it again to rinse your machine. When its done exit the descale mode and go to the "Reset descale" just under it and enter. Choose "Yes" and push the enter button to accept. It will tell you when it needs to be descaled again.
If you want to make your machine last a long time, go to the water hardness in the menu and change your water hardness to the #4 and always push the enter button if you want to make your changes permanent. If you don't, no changes will be made and it will still be the same when you exit.
Posted on Jan 06, 2011
No se prende y no se puede reconocer
la pantalla se pone como leyendo archivos y solo se queda en eso...
y cuando lo conecto a la pc aparece algo asi: The timer and alarm will become invalid
Oct 30, 2011 | Sony Walkman NWZ-E344 Digital Media Player
Mi camara canon powershot A3100 IS se apaga automaticamente y aparece en la pantalla se ha detectado un error. debe reiniciar la camara y yo no se como solucionar eso porque no he podido reiniciarla. como...
TENGO UN PROBLEMA CON MI CAMARA POWER SHOT A 3100 IS LA MISMA PONE EN LA PANTALLA SE HA DETECTADO UN ERROR DEBE REINICIAR LA CAMARA DIGAME COMO SOLUCIONAR ESTE PROBLEMA MI CORREO ES josemm22@yaho.com
Aug 28, 2011 | Canon PowerShot A3100 IS Digital Camera
Como resetear dcp165
Instrucciones para reparar el error 46 DCP-165C
Desconectar el enchufe de CA
Conectar de nuevo el cable de CA mientras mantiene pulsado el bot?n "Men?"
y manten?rlo presionado (por 15 seg)
ahora est?n entrando en el modo de mantenimiento aparece en la pantalla LCD "error 46"
Seleccione 8 utilizando el boton de flecha hacia arriba, pulse OK
seleccione 0 y pulsar OK
00:00 00:01 OK (en la pantalla se muestra este mensaje)
Presionar la tecla azul (star black) 25 veces hasta que salga PURGA: xxxxx
Seleccione 2, ok.
Seleccione 7, ok.
Seleccione 8, ok.
Seleccione 3, ok.
El contador de la purga indica ahora: purga: 00000
apaga la impresora, (desconctar el cable CA)
listo para imprimir!!!
May 26, 2011 | Brother DCP 165C Compact Color Inkjet...
COMO PUEDO QUITAR EL MODO DEMOSTRACION DE UN SONY BRAVIA 32BX3000
Entras al menú .... ajustes.... inicio automático. Ahí empieza una configuración inicial del TV y encontraras una seleccion de Modo entre Tienda y domestico. Seleccionas domestio y listo.
Un saludo...
Nov 02, 2010 | Sony Televison & Video
Pantalla dice purga y no funciona el mecanisco para hacer cafe
compre una cafetera saeco royal al comienzo todo funcionaba bien
pero despues de un tiempo cuando la enciendo sale un letrero
que dice ''ventilate'' y no funciona ninguno de los botones.
que puede estar sucediendo?. gracias
Feb 21, 2010 | Saeco Royal Professional Espresso Machine
Printer does not print error mes. unable to clean
you need a nwe waist ink absorber which can be purchased at any service dealer near your home (see www.brother.com)
Apr 05, 2008 | Brother MFC-3240C All-In-One InkJet...
Brother printer MFC 210C
ok el error 46 o unable to clean en las impresoras brother se debe a que llegaste al numero maximo de purgas de cartuchos por lo cual la impresora supone que el wasteink o el deposito donde tira la tinta esta lleno y para evitar que se tire y te haga un desorden monumental recomienda que lo cambies asi por lo cual se sugiere que si no quieres comprar uno nuevo abre la impresora y cambia la esponja.
cuando el contador de limpieza llega a 6400 se genera un error interno machine error 46. asi que las futuras operaciones de limpieza son prohibidas and la impresora no se puede usar
Pero no te espantes ya que tiene arreglo.
Como Reseteando ese famoso contador
como ok
no te voy a complicar
primero daz click en menu/set
y presionas *2864
pero ojo ojo esto lo tienes que hacer todo en menos de 2 segundos
como sabras si funciono si funciono al menos en este modelo mfc 210c empiezan a parparear los botones photo capture copy fax y scan
eso es que si funciono si no funciono presiona stop y vuelve a empezar recuerda menos de 2 segundos
y en la pantalla dira maintenance
ahora el codigo para mantenimiento es 80 presionas 8 y seguido el 0
dira la hora y al final ok
ahora presiona el boton black start son segun las conte como 24 veces te va diciendo datos de la impresora el que nos interesa dice purge:06400
ya estando ahi metemos el codigo 2783 y se pone en 0
ahora presionas el boton stop para regresar al menu anterior dira maintenance y ahi presionas 9 una o dos veces dira please wait hace un reinicio prende y lista para usarse nuevamente
posteado por SYSTEC DURANGO
soporte@tododurango.com email/msn
www.tododurango.com/soporte
Feb 15, 2008 | Brother MFC 210C All-In-One InkJet Printer
Saeco Royal Professional Espresso Machine Logo
831 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
