Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
Broken pull cord
My cord came disconected what is the best way to fix it so it dont happen again
Rightside headset not working just leftside
Sounds like you have a broken or lose wire. This happens a lot due to pulling on a cord or just bad connections sometimes. A lose wire should should have sound again if you move it around. You can try and solder it back, if you have the know how or there is not a lot you can do. Also, it could be your system you are plugging it into but this is rare. Sorry, best I can do....
Oct 20, 2015 | Radio Communications
Cub Cadet has broken pull cord
pull off cap first from engine look inside it pull the rest of the cord out to the end then grab the not onthe pully while holding it pull the rope out after that wind pully all thee way up shuve a new cord throug houseing pully then slowly let rewind up until it stops cut the rope 6 inchs in front of cap hole restall cap to motor slip your starter rope threw grip that you pull pullthe cord attached to handle out two feet hold onto rope cut handle loose slip[ and tie handle again to the houseing rope dont let go of the rope after that let it rewind back up done
Sep 04, 2013 | Garden
Lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
May 04, 2010 | Mtd 22" Yard Machine Push Mower
It wont turn on, i can charge it and the computer makes the sound that its plugged in and the buttons start flashing but nothing on teh screen pops up. ive tried reseeting it but i think the button is...
ok take the screen and the play/back buttons off and gentely lift the screen dont pullit off completely it will never work again there is a cord or what ever connecting the screen to the cercuit board do not disconect it or put a rip in it while you are lifting the screen. once you do that you will see two screws take those two screws out put them to the side in a safe place (the screws i mean) once you do that lift the curcuit board up and there will be a cord connected to the battery and cercuit board disconnect the cord from the battery end. once you do that flip the curcuit board over you will see a peace of electrical tape pull it off then reconnect the battery and put it all back together. if you have any questions email me at BLACK4DOOR1989@YAHOO.COM
Feb 27, 2010 | Creative Labs ZEN V Plus MP3 Player
Why does 1986 cutlass battery keeps draining when battery and alternator test good
youve got a short!!!!
with the car off and everything turned off
disconect the postive battey cable,if you get an arc then youve got a short
hook it back up and pull one fuse
then disconect the battery again
repeat this process till you dont get an arc
then you will find where your short is
Feb 23, 2009 | 1986 Oldsmobile Cutlass Supreme
Power windows, door locks and mirrors are not working
ok this is a decently common problem. there is a black wire and an ornge wire in the wire bundle to the driver door.disconect the battery, then pinch the taps on the black shielding going in to the door and pull out the junction, pull the black shielding back and disconect the harness to the door, then pull the shielding all the way back and fix the one or two broken wires. good luck and i hope i helped enough if not id be glad to awnser more
Jan 13, 2009 | 2004 Jeep Grand Cherokee
Engeen stop working no reason
Same thing happened to me. I had no current comming to the ignition, no lights in the dash. I took out each relay and put it in again. Also i disconected all wires joining the ignition an reconected again, and any joinings comming from battery to ignition. I dont know what helped but it started anyway and runs fine.
Aug 18, 2008 | 1992 Volkswagen Golf
Electrical Problem
I would operate one by one mirrors left-right,radio, electric locks.
I would first dont operate side mirrors and observe if fuse remain then leave radio disconected (dont power on or remove its wire harness). If with radio disconnected fuse is not blown, i would use electrical locking and test again.
Good Luck
Jul 07, 2008 | Hyundai Motor 2002 Elantra
Power supply issues
Have you checked the AC power pin (where the AC cord plugs in)?
Chances are that the pin has come loose from tugging and pulling on it. When this happens the battery charging is intermittent at best. The parts to fix this problem are usually under $10 but the labor if you take it in is gonna run $100-$200. You can repair it yourself if you're comfortable working with electronic components. Not that tough. WHen you get it fixed, invest in a Cable Retention device to keep it from happening again.
Here's a short video that talks about it. . .
Feb 26, 2008 | Dell Inspiron 710m Notebook
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
76 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
