Question about Samsung 4 Channel Dvr
Samsung SDS-4001 camera views and recording functions quit working properly after a power blink. Appears to need a system re-set bit I don't know how.
Is there a re-set button I can't find?
    President:
  • 2,976 Answers
You should be able to reset the system by unplugging it.
Posted on Dec 14, 2012
2 Suggested Answers
SOURCE: The samsung monitor ssc21web shows system initialize... the three periods blink
ssc21 web does not work, It was a cameras shut down it says LA and AL why
Posted on Apr 13, 2010
Remote and mouse do not work on samsung sde 4001 security system
Easy fix...because you are using VGA screen ...you need to push pretty fast on your remote the following ( do this twice) fast....push. Freeze. View. Return. That should fix it. If twice oes not fix it keep doing it...it will work. Good luck.
Dec 28, 2012 | Samsung Home Security
How do i view my security system on line using my apple laptop system is sde 4001
You won't be able to access the system from a different network without changing some settings in the router. You will need to find out what ports the security system uses. If you bring up a web page to monitor/configure the system, then you'll most likely use port 80 (HTTP) or port 443 (HTTPS). If you see "www.something.com:3948", the port is the number after the colon.
You will need to go into the router and enable port forwarding to the IP address of the security system.
Oct 22, 2012 | Samsung SDE-4001 8 Ch DVR Security System,...
I have sound and can view previously recorded videos on my camcorder. However, on Christmas morning my camera doesn't record or view images. It just records a black screen with white lines. The li
The recording head is probably the source of the problem and will need to be replaced, other than putting a dry cleaning tape or better still a new blank tape, allow it to play right through, it may work.
Mar 10, 2012 | Sony Handycam DCR-DVD105 DVD Camcorder
My vx2100 plays back every time I record something. I don't know why but it's super annoying. I figured the search buttons on top are loose or broken but I don't know. Is there any way I could...
The VX2100 is quite a complicated camera and can be easily damaged during disassembly. I don't know of any setting that would cause this to happen but you can try resetting the camera functions pressing the rest button to see if this goes away. Otherwise the camera should be repaired by a qualified technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 04, 2011 | Sony Handycam DCR-VX2100 Mini DV Digital...
My recorder isnt working
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution. Thank you for choosing FixYa to solve your problem. The recording feature of your electronic device isn't working properly? You should try turning the volume up on the microphone so it can pick up your voice clearer when talking. If you still can't playback any recordings, check the volume settings of your device on your computer. This is located in the Control Panel (Windows) and the System Preferences (MAC OS) applications of your computer. Go into your operating system's preferences and increase the microphone volume. You may also need to select your headset device as the default recording device (Windows) or the Output Device for recording (MAC OS). If you want my opinion, I think your headset device is not set as the default recording device. If you don't have a headset as the default recording device or output recording device, you can turn the volume up to the maximum setting and you still won't be able to record anything because the computer has another device (if any microphones are installed in the PC) as its default or output recording device. That's why it's important to check your system preferences for a headset to make sure it has the proper settings. I hope you understand this solution and that you can record audio on your headset. Reply back if you need step-by-step instructions.
Jul 01, 2011 | Logitech ClearChat Stereo Headset Headset
Samsung digimax 301 digital camera
This is a system failure and reference to the Samsung support site will either offer to repair or simply replace with a new camera [some models are not repairable]
Aug 30, 2007 | Samsung Digimax 301 Digital Camera
Panasonic NS-DV 65 video camera, Tape not detected?
TRY THIS, (CREDIT TO LABBER) IT WORKED FOR ME
I did have a similar problem as above, and has not been able to use the camera for a long time as power turns itself off in less than 2 mins. I tried the solution #3 (by labber) above. which i have copied and pasted below .
1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in.
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on you should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS HOPE THIS HELPS.
EBEN
Dec 06, 2006 | Panasonic NV-DS29B Mini DV Digital...
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung 4 Channel Dvr Logo
192 people viewed this question
Top Samsung Home Security Experts
Mike
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
