Question about Maytag Dishwashers
Maytag dishwasher makes whistle noise
The whistle noise starts while dishwasher is working.
  • 10 Answers
SOURCE: maytag dishwasher
The insulation around the machine is not supported all around.
Posted on Dec 15, 2007
SOURCE: kenmore dishwasher making whistling noise
Could be a clogged spray arm... take it out and give it a good cleaning. That might help.
Posted on Feb 05, 2010
SOURCE: Our LG LDF7920st dishwasher (6 months old)makes a whistling noise
Hey, consider the float assembly!
We bought this dishwasher and ran it for the last 1 1/2 months and it made a grinding and whistling sound from day one (it's supposed to be nearly silent in its operation). Turns out the drain pump was cutting in while the machine was still filling, thereby emptying the wash tub of any water. Then, when the cycle proceeded to wash, the dumb thing had no water and made a horrible noise. So I had to pitch in at least 2-3 litres of hot water, and then it worked quietly! Had to do this every time there was new water intake.
After working with the repairmen - four visits later, we isolated the float assembly as the problem and they set about replacing the part. Turns out the two parts were markedly different. LG HAD INSTALLED an older model float assembly at the factory and it was the problem. The replacement part was the correct float assembly and things worked perfectly after that - thank goodness. No more babysitting the dishwasher.
Don't let anyone tell you the motor assembly needs replacement. I have seen that cop-out 'fix' all over the web. But use deductive reasoning to find out where the problem is in the cycle, and explore this option first - it's a quicker and cheaper fix than replacing the whole motor assembly.
'Mr. Float' as he is now called works like this:
-expels any residual water in the tub from the last wash
-intakes water for the wash or rinse
-whirs 2-3 times prepping for the cycle
-begins to wash, quietly
-expels at the end of the wash or rinse.
He used to:
-expel residual water
-intake new water for wash or rinse
---drain pump would cut in WHILE still filling
-machine would whir once, realize it didn't have enough water
-perform a brief top-up intake shot
-begin to wash and whistle and GRIND (this is where I would have to add the water)
-expels water from wash or rinse, and start all over again.
It's a good dishwasher and it will work, but the right model parts have to be in place!
Posted on Jun 02, 2011
  • 500 Answers
SOURCE: my 1yr old dishwasher is makes a whistle noise
Hi jgonsalves,
Please check my following tip for the full solution to your problem.
Click here -> L.G E1 Error / Whistling Sound
Kind Regards :-)
* If you found this solution helpful, please rate it.
Posted on Jul 06, 2011
j_gilliland1
SOURCE: High pitched whistle
did you ever get a resolution on this? mine just started doing this it's about 2 years old...
Posted on Oct 11, 2011
Why my dishwasher whistles?
Whistle could be inlet water pump,leak will have to be traced could be from a number of places,poss from pump
Aug 13, 2014 | LG LDF6920ST Stainless Steel 24 in....
Ssangyong whistling noise in turbo
sounds to me the blow off valve is working for the turbo mabye deffective .
May 04, 2014 | 2010 SsangYong Kyron 200Xdi
Dishwasher is not working
10 years is probably the full life of your machine. I'm guessing that the problem is in your electronic control board and that part, itself, runs around $100 plus. And, if you add a service call, you pretty much have the price of a new, basic dishwasher. And this is assuming that the part is still available for a 10 year unit. Should you decide to replace the dishwasher, look for a Best Buy in your area and keep checking the 'open box/closeout' section on the store's website.. there are often very good buys (for instance, a Phoenix store has a $850 Kitchen-aid priced at $432) in that section. There are also several online dealers that include shipping in their price. If you shop around, you can probably find a basic dishwasher - minus the bells and whistles - for well under $300. Good luck.
Mar 14, 2014 | Dishwashers
Makes a whistling noise when in use
I had a problem with my LG dishwasher and there was a small stainless steel impeller that they had to replace to stop the high pitch noise. I think this impeller grinds up any food particles. The tech said if one of the veins bend it causes this issue.
Feb 10, 2013 | LG 24 in. LDF 7811 Built-in Dishwasher
MDB7100AWW Dishwasher has started making a load noise during operation. Still working for now.
either your main pump is going bad or the drain pump is going bad. it is possible that there is something stuck in the sump causing it to make noise
Oct 24, 2011 | Maytag Dishwasher
My 1yr old dishwasher is makes a whistle noise
Hi jgonsalves,
Kind Regards :-)
Jul 06, 2011 | LG LDF6810ST Stainless Steel Built-in...
Gas Oven Whistling noise
I HAVE A NEW PROPANE OVEN THAT I CONVERTED TO NATURAL GAS. NOW I GET A WHISTLE WHEN I USE THE OVEN ONLY. DO NOT GET A WHISTLE WHEN I USE THE TOP BURNERS.
Jun 23, 2010 | Maytag Ovens
Dishwashers Logo
142 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
