Question about Xerox WorkCentre XL2120 Laser Printer
L6 error code
What is this code and how do you fix it?
    Sergeant:
    Champion:
  • Xerox Expert
  • 351 Answers
The scanner underneath the glass needs to be replaced. A very common problem.
Posted on Dec 12, 2012
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
L6-10
According our service manual 'L6" sub code 10 is laser drive, motor, problem, replace laser unit . the laser unit item# is DUNTK0013QSZZ, it located at left hand side of the toner cartridge inside the machine. or it may be mostly due to Polygon mirror motor not up to speed... You may be able to air it out and fix the problem.
Jun 19, 2009 | Sharp AR-M450N Copier
The L6 code is flashing on my copier
No you can't, it is the polygon motor not rotating. It is inside of the Laser unit. You should replace the polygon motor. The part code is RMOTN0028QSZZ. It will cost you about US$ 80
Jun 04, 2009 | Sharp AR-160 Copier
Error code l6-10
Hope this helps.
Apr 24, 2009 | Office Equipment & Supplies
Error code L6
L6 is a Polygon Motor Lock
You could try to reset the machine with a simulation code 14, which to perform it:
1. Push Clear, Auto, Clear, Auto in a steady rythmic fashion. If done correctly the screen will go blank and all the lights will turn off. If done incorrectly wait 15 seconds then try again. Clear is the red "C" and auto is on the left hand side, the word auto directly above the button.
2. Once you're into this mode enter the number 14 as if you were doing 14 copies then push the green copy key.
If the L6 returns after the reset then you will need service on the machine, Sharp will fix it for a flat rate charge of $140.00 for parts and labor out of warranty. Give them a call 1800 237 4277 in this case.
Dec 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp ar-m160
if you press the print switch while the l6 code is in the window you will get a second code. more than likly it will be a 10 that means your laser unit is bad & needs to be replaced.
Nov 12, 2008 | Office Equipment & Supplies
ERROR CODE L6
possibly low systm battery.......
Oct 17, 2008 | Kidde Nighthawk Combo Gas/co Detector
Error code L6-10
sir, I ma indian & I have a tosiba estudio 161 I have problem diaplay in on display screen when i switch on the start so display show screen ---
Jul 02, 2008 | Toshiba e-Studio 161 Copier Copier
I HAVE AN ERROR CODE L6 ON A SHARP AR-163 PDIGITAL IMAGER. WHAT IS CAUSING THIS ERROR AND CAN IT BE REPAIRED IN-HOUSE?
Apr 18, 2008 | Sharp AR-M160 Laser Printer
Sharp -AL1644 flashing L6 error
Feb 29, 2008 | Sharp AL-1641CS Laser Digital Copier
Xerox WorkCentre XL2120 Laser Printer Logo
132 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
