Question about Thomson DVD3660H DVD Player F3Y021BF2M HDMI 1.4 Cable - 2 m THOMSON
Instruction manual missing
Need to programme
  • Thomson Master
  • 5,349 Answers
Allways best to check the Thomson website. Some makers have them as a Free PDF!
Posted on Dec 17, 2012
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Tip
How to make older programmes run on xp.
Find the launch file that you want to run. its normally the main executable programme or shortcut.
right click the icon and select the properties.
click on the compatibility tab and place a check next to the text labeled "run this programm in compatitbility mode,"
select the operating system that the program was designed for.
you may need to adjust the display settings also for this program.
click apply
then restart the programme see how it goes.
if the programme does not work try differnt compatibility modes.
on Dec 01, 2009 | Computers & Internet
How do you get rid of the 3rd programme on the draytonLp 112 mk1 programmer
set the on and off times the same on programme two for example on time at 12 then off time at 12 this will in effect nullify programme Number two
Oct 16, 2012 | Heating & Cooling
ST6400C programmer, heating switched off. Switch hot water on only, tank full of hot water but pump runs and radiators get hot. Wall stat is set at zero. When programmer is touched and the flap dropped to...
Have had a lot of these programmers with this fault.Integral fault with electronics.Programmer will need to be replace as unrepairable.You should be able to find a straight replacement version from your heating supplier.
May 11, 2011 | Honeywell Programmable Thermostat Heater
AEG Lavamat 74810 - Spin only programme?
need make and model .
but most machine's do have spin only programme. so turn your machine to this position look for the spin programme after sythetic this is normally slower .and turn on.Iif you can't find spin please let us have make and model .
Feb 11, 2010 | Washing Machines
Changing boiler programmer
take digital pictures - label all wires and reconnect - you do not need manual.
Oct 27, 2008 | Water Heaters
Hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Thomson DVD3660H DVD Player F3Y021BF2M HDMI 1.4 Cable - 2 m THOMSON Logo
131 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
