Question about Pool & Spa
2 Speed Flo-Master stuck in high speed after turning on and off the electric
I have a Flo-Master Aqua-flo two speed 1.5 - .18 SF pump on my hot tub. Turned off the electric to the pump for spa maintenance, the next day turned it back on and it automatically is on the high speed. It will not switch over to the low circulating speed when pushing the button. Tried turning on an off the electirc again and same problem. Stuck in high speed. Any help is appreciated.
  • 8,404 Answers
Is your switch an "air switch" ... could be you have a leak in the hose that connects from the push button to the actuator that actually does the switching. Check it out.
Posted on Dec 13, 2012
2 Suggested Answers
adamh294
  • 310 Answers
SOURCE: I was told that the Aqua Flo Master Xp2 Spa pump
I responded to the previous question in regards to the motor only. The xp2 does not have the strainer basket that the max-e-pro has . If this was a regular hot tub, the xp2 would work great, if this is above ground, then you do need a pump with a strainer basket. Again the xp2 will not work for an inground hot tub as the set up is different than an above ground unit.
Posted on Jan 13, 2011
Testimonial: "Thank you so much. That helps alot. Do you have any other suggestions for a pump tha might be less expensive then a Max E Pro?"
Switching jets on trips RCD
This is usually an indicator that the high speed on your pump is bad.
Rod
US Parts Center
May 04, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Aqua Flo Flo Master won't start on low speed
Water flow error on hot tub means low water flow. This is not enough water flow to turn the system on.
Some motors do have a start capacitor on them. you can certainly check that or take it to your local motor repair shop and they can check that for you.
Rod
US Parts Center
Jan 13, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
Changing hot tub pump flo master power cord to new waterway pump diagram say common white line to port no 1 port no 1 hase an orange wire on it allready wire leads in to motor housing. not sure where white...
DO NOT PLAY AROUND WITH THE WIRING OF THIS 2 PEED.
you can cook the motor in just a few seconds != junk
yes WHITE is common RED is low and BLACK is high
A picture of the connections in the back of the motor is needed for further assistance
Jay the pool pump repair guy in longwood Florida.
Mar 02, 2018 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I was told that the Aqua Flo Master Xp2 Spa pump 1.5 hp 2 speed pump was the equivalent to the Sta rite Max E Pro 2 speed pump but then from another source was told that the Aqua Flo was not made for in...
Jan 12, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Hot tub pump flo-master hp suddenly wont start. it' one year old and was working perfectly. air side started to make a squealing noise the night before. draining hot tub to check volute to make sure motor...
The fault is most likely to be the condensor. They can and do fail at an early age.
You don't need to dismantle the pump, on the rear of the pump you'll find a slot on the motor shaft which can be turned with a screwdriver.
If you've only just reffiled the hot tub it could also be an airlock.
Regards,
Ian.
http://hottub.synthasite.com
Apr 18, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Wiring diagram for flo-master 56 frame xp2. I have a new pump that was improperly wired from the factory.It is a two speed pump only running one speed. If I knew where the factory wiring should be...
The side of the motor will have a wiring diagram for how to connect the common, low and high speed leads. Your wire harness should have a white (common), black (usually low), red (usually high) and green (ground) wire. If high and low are backwards, switch the black and red leads.
Nov 23, 2009 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
I have a flo-master 06620390-2 pump that failed in my hot tub. Is there a quieter and more efficient replacement or should I replace with same?
You are generally better off replacing the pump with the same model. Hot tubs are noisy unless you have a really good insulation job. It is unlikely changing the pump will make it any different as far as noise goes. The flip side is that the manufacturer sized the pump to match the hydraulic load present within your specific tub and to provide the necessary flow rate to keep the water clean. It can lead to problems if you put in the wrong replacement unit.
If you would like a quote on the replacement motor and/or pump end, contact us thru www.arrowpools.net.
Sep 10, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Pool & Spa Logo
91 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
