Question about Hobart N50 Stand Mixer
The gear is slipping on my Hobart A200
I believe the gear is slipping on my Hobart A200 stand mixer. I was making bread when the machine started to make a strange noise. The dough hook still spins, so it cant be the motor. The other problem I have is that the dough hook is stuck on the machine, I have tried hitting the stem and under the hook with a mallet, dropping in penetrating oil and soaking it with water, nothing seems to work. I would be very thankful for any help. Candy
  • mail544 Mar 18, 2009
    I have replaced the worm gear shaft on my old hobart a200 mixer with a fibre cog the problem now is that the motor spins but I can stop it with my hand then it will not go again. I think? the problem may be the spring clip because I think I put the cogs on the transmission shaft back together correctly.
  • 640 Answers
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Posted on Jan 14, 2009
How to invert motor turning direction?
Hobart A200 Stand Mixer
Beatriz, I looked through the entire manual, it shows no reverse option. Did you just get the mixer or did you have it repaired. It seams the mixer is either wired wrong or the gears that rotate the mixer were not assembled correctly.
Check the attached link,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://my.hobartcorp.com/kroger/TechnicalServiceManuals/A200%20Technical%20Manual.pdf
A200 Hobart Service
Apr 06, 2016 | Hobart A200 Stand Mixer
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
Hobart A200 mixer 1st speed doesn't work 2nd and 3rd work fine
Could be that a gear is missing (broken) on the shaft that works the 1st gear. Check out the schematic at
http://www.food-equipment.com/parts_Hobart_mixers.htm
It could be the gear HM2-748
Feb 22, 2010 | Hobart A200 Stand Mixer
Hobart A-200 3943. Having a problem with torque.
Check your recipe against the capacity chart found here: http://www.primasupply.com/images/hobarta200.pdf
You may be overloading the unit. Hope this helps.
Oct 13, 2009 | Hobart A200 Stand Mixer
Hobart A200 diagnosis
the first A-200's have a worm gear drive that will slip when old but also when mixing dough somtimes the dough will push the mixer aherad of its self and look like its slowing but its just catching up. if you have a old worm shaft it will have a spring on it is how to tell. it is replaced with a shaft that is all keyed and has no slip or give unless a key shears.
Michael
Nov 25, 2008 | Hobart A200 Stand Mixer
Gear problem
Sounds like a sheared key,explain your problem a little more i work for hobart.
Jul 26, 2008 | Hobart A200 Stand Mixer
Hobart A200
Hi I work on these all the time, sounds like a tooth from the one of the gears has sheerd off so making the gear rings rotate when they should sit solid in its casing..... you need to open her up or get a tech to look at it £150 is an approx fix
fritz
Hobart N50 Stand Mixer Logo
577 people viewed this question
Top Hobart Food Mixers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
