How do I adjust the belt tension on Ariens 926 LE snowblower
    Sergeant:
  • 462 Answers
Should be a manually adjustable tensioner or spring loaded on against your belt somewhere
Posted on Dec 13, 2012
How do I adjust the belt ona Toro 726 snowblower
There should be a tension pulley between the main pulleys. Usually it is mounted on the side wall and can be adjusted with a nut and bolt.
Mar 16, 2016 | Toro Power Max 726 OE Snowblower - 37771
Start my new snowblower auger keeps turning
Belt is a bit too tight. If it's NEW it will probably stretch a bit and be OK
Dec 23, 2014 | Ariens 72023 Snowblower Drive Belt 1/4 X...
Parts not available for Ariens ST724 snowblower?
No you do not..you have the model number and hp should do it ..go in on your computer and just put the name,model number,hp and model in that order .or better yet go in on eBay and put that in and most likely you will find it a a reduced cost..good luck
Nov 10, 2014 | Ariens Snowblower Belt 72098, 8hp 1/2 X 37...
Why does the wheel Drive seems to slip / stop ?
no tension adjustments replace fluid and filter should improve
Jul 16, 2014 | Ariens Garden
10 snowblower
Just a matter of the output shaft. If the height of the engine is slightly different, that can be adjusted by buying different sized belts But the Length and size of the Shaft that the Belt Pulley will be put on is the critical item
Dec 05, 2013 | Garden
Ariens SnowBlower I recently blew a belt on my Ariens 5.5 hp snowblower Mdl# 932140 I replaced it and it blows snow and when i put it in 1st gear the machine goes into reverse. All my other gears work...
Hi dwva, I think you have the belt on properly seeing the other gears work fine. The difference between 1st and reverse can be as little as 1 half in on the drive wheel. It depends on which side of center is the friction wheel riding. Remove bottom pan with the machine in 2nd or 3rd gear notice which side of center is the friction wheel riding. (the friction wheel is the one with a rubber outer ring). Now put it in 1st, is it on the same side of center? There is an adjustment on that linkage, adjust so in 1st is on the same side of center. Happy New Year, hope that helps.
Dec 29, 2010 | Garden
How to install spring on Ariens chute
Not a DIY fix as took the snow blower into the shop for them to repair it.
Oct 20, 2009 | Ariens Garden
How do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Oct 12, 2009 | Ariens Garden
Computers & Internet Logo
405 people viewed this question
David Payne
David Payne
