Question about Sharp Office Equipment & Supplies
Sharp AR 5618S Error code - Sharp Office Equipment & Supplies
  • 28 Answers
SOURCE: sharp ar-m160
enter the simulation mode:
"#" key Interrupt key "C" key Interrupt key
press 14 and START key
the copier should restart in most cases.
if not:
There is a problem in the fusing area, bad Thermistor, defective ThermalFuse, defective heating lamp.
Posted on Feb 05, 2010
  • 33 Answers
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Posted on Jan 02, 2008
  • 2072 Answers
SOURCE: SHARP AR-M277
this should resolve it.
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly.
Posted on Jan 22, 2008
Benimur
  • 6966 Answers
SOURCE: printer all in one sharp ar-m155
Hi again,
Sorry but not the wire, I was referring to where the wire is attached, both ends. This would either be a clip-on or sandwiched between 2 small plates held together by a screw. It is not uncommon for this clips or plates to be tarnished or have burns. They have to be cleaned, if not current will not flow freely to the corona wire. The purpose of the wire is to draw the toner from the drum onto the paper, it uses static electricity to coat both the photoreceptive drum and the paper with a layer of positively charged ions. If the corona wire is not getting full charge or no charge at all, this is the primary reason the warming up is taking too long.
Additionally, try to enter service mode; try #, *, CA, #.
To reset the developer counter press 24, Start, 5, Start.
To exit press reset 3 to 4 times or turn main power off/on.
Would appreciate further updates.
Posted on May 03, 2008
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
Sharp ar 5618s f2 error
check the toner or drum cart. if third party replace with OEM
Jul 22, 2015 | Sharp Office Equipment & Supplies
Code for develpoer in sharp ar-5618s
to obtain developer code you should contact the manufacturer
Jun 04, 2015 | Sharp Office Equipment & Supplies
Why is my Sharp ar-5618s showing a green light on the mainboard?
green light on the main board normally mean good!!!! why looking at the main board???
Apr 07, 2015 | Sharp Office Equipment & Supplies
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
"SHARP COPIER AR-5618S, A NEW COPIER, TONER EMPTY, I REFILLED IT, BUT TRIANGLE RED LIGHT IS..."
Your problem is that you should not use refilled toner in you sharp copier but if you chose so you have to change also the chip in the end of the toner it will work fine
Jan 30, 2014 | Office Equipment & Supplies
SHARP COPIER AR-5618S....TONER EMPTY. IT REFILLED. BUT EMPTY SIGNAL ALSO NOW.PLS SAY ITS RESET CODE
No reset code ;once you replace with new toner it should be ok.
Do not switch off machine when replacing.
Jan 30, 2014 | Sharp Office Equipment & Supplies
Sharp AR 5618S Error F2
Hope this help.
Hold down the copy start button
You will get F2 flash then 2 numbers will flash
http://www.manualslib.com/manual/902246/Sharp-Ar-5618.html?page=55#manual
Jul 06, 2012 | Sharp Office Equipment & Supplies
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code Sharp AR-M 257
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
216 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
