I have this router linskins just i want to know if the router work good because sometimes the signal dies and go too slow
  • 242 Answers
Not sure which model Linksys router you have here but it's probably OK. Considerations regarding router speed and dropped wireless connections can occur because of construction and distance. If this router is downstairs and your wireless computer is upstairs then the connection may drop due to the materials and thickness of the ceiling/floor between them.
Another consideration is the number of wires connecting your devices. Make sure that the wires are clearly separated from each other and not bent or crimped. A power cord wrapped around a CAT5 cable can cause electromagnetic interference and create problems for the router.
Posted on Dec 12, 2012
All wireless products are slow
Your wireless router is to blame for this one. You need to raise it up as high as you possibly can, and also it needs to be placed in a spot with the least amount of interference or signal blockers in the way such as walls, ceilings, and floors between it and the wireless products requiring it to function! Another possibility is to add to the network another "ACCESS POINT" or wired to wireless router at the highest possible point if you cannot move the 1st router. A totally wireless router will work but it has to have a strong wireless signal (from the 1st router) to work properly.
Good Luck!
Rich Lilja
Dec 30, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
I have a Zyzel nbg416n wireless router. Ive had it for 5 days and its constantly dropping the connection. Connection via an ethernet cable is fine, it's just the wireless aspect. The connection...
Wireless routers do what is called signal shifting. This means as the signal gets weaker (either because of distance or because it has to pass through walls, strong electrical fields etc) the speed is automatically dropped to as low as 6mbps. All the obstacles will kill your signal very quickly as well. You can try moving your router to a better location or invest in a repeater to place between your wireless router and the computer.
Sep 15, 2011 | Zyxel Communications NBG416N 11N 150N Wlan...
Network always failed..slow browsing..sometimes no signal
This happens with some commercial router brands over time. I have had Dlink, Netgear, Linksys, TrendNet all succumb to this problem. Usually about every three years or so I start to notice lower and lower QOS. If your router is that age, I suggest replacing.
Mar 26, 2011 | Computers & Internet
Lynksis Wireless Router does not stay connected to the Internet.
I suggest checking the documentation of your linksys router in the linksys site. Get the manual and that would tell you how to set it up. Regarding the router being broken, it is possible. Are you wired or wireless to the router?
Jul 22, 2009 | Linksys Wireless-G WRTP54G Router
D Link Wireless N router keeps having to be re-set
I've seen this on a router that was broadcasting very little signal. (in my case the next day it died. When the laptop is running move away from your router and try to determine where it loses signal strength. A router is good from the factory for about 200 feet with no obstructions. In most homes I give them 30 to 40 feet. Be aware that windows and glass doors nowdays use a metal mylar film between the glass to reduce infrared rays. If you lose the signal very soon then I'd say the router is dying.
Good Luck
Mar 22, 2009 | D-Link Computers & Internet
I recently purchased a new MAC and can not get a wireless coneection to stay put. It moves very slow or kicks me off.
Check your signal strength. You may not have enough bars. Also check and make sure your signal level on the router is set to the highest setting. If you don't know how to do this let me know.
Jan 18, 2009 | Linksys (RT31P2) Router
Good Signal,Good Mbps, Slow Internet Connection?
1. Try to use a different wireless adapter on all available USB ports, if the problem remains then
2. turn off your PC unplug the power cord from the power socket, short the two legs of the power cable then leave it for 5min, then plug it into the power socket again and turn on the PC.
if this didnt work then you have a hardware problem with the USB ports.
let me know how it works out.
Nov 30, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Router problems
I've seen many routers die this way. Belkin routers have a tendency to go intermitant before they die. If your computer can get onto the net when connected to just your modem, then the router is the answer.
Good Luck
Sep 28, 2008 | HP PAVILION A6230N DESKTOP PC
Slow link to internet on new Vista Lap top
speed of getting connected is depending on how you have secured the signal.
When connected is everything OK. If Yes try onother channel
If No then I need more information about your settings.
Good Luck,
Pascal
Jan 17, 2008 | Belkin (F5D8231-4) Wireless Router...
Fast Page Loads Slow Downloads
it really depends on how far you are from your Router. The farther you go, the weaker the signal gets resulting in slower speeds. Slower speeds will not affect web page load times (they are tiny parts of data) but will definately affect download speeds. You need to be as close to the router as possible or get perfect range. You can put the router at higher elevation in the room to get a better range to start with. Let me know if this works for you.
Dec 20, 2007 | ASUS WL-700gE Router
Open Questions:
Computers & Internet Logo
David Payne
David Payne
