Question about Tascam DP01 All-In-One Recording Package Microphone
How do I fix a media error=0 from my dp-01 fx/cd tascam?
This just came up for the first time. All it say is the error message and turn off power.
SOURCE: tascam dp-01fx system 50 error
what the above guest said is exactly what you need to do. Make sure of course there is nothing on your FAT(previously exported songs/masters) because they will be erased. just go to menu->disk->fat reform, then press enter
Posted on Dec 18, 2007
  • 189 Answers
SOURCE: Tascam DP-01 FX/CD Digital Portastudio
Here's a link to a forum where someone else encountered the same error. Seems it was due to running out of disc space in that instance.
http://www.tascamforums.com/lofiversion/index.php/t10089.html
Posted on Jan 03, 2008
  • 189 Answers
SOURCE: Tascam DP01 wont get past please wait screen
Usually an indication of bad sectors on the hard drive. This can be caused by bumping the unit when it is running, excessive vibration, a power failure while it is on, improper shutdown, or expoure to a strong magnetic field like having a subwoofer too close or an intermittent faulty power supply.
Your options are to return the unit (if it is still under warranty), or if not to open up the DP-01, remove the hard drive, connect it to a PC and perform a low level format (or take the drive to your nearest PC repair shop and have them reformat it).
Unfortunately you'll lose any data that wasn't backed up, but this should bring back your DP-01.
Posted on Jan 05, 2008
  • 189 Answers
SOURCE: Tascam Portastudio DP-1FX/CD
This is basically an error message which indicates that the Tascam timed out while waiting for the drive to spin up. Usually an issue with the drive motor not getting the correct amount of power.
Primary suspect is usually the power adapter.
Cheers
BD
Posted on Apr 23, 2008
SOURCE: DP-01FX/CD Problem
nslo, tell him to try replacing the power supply first, power supplys burn up ALL the time, as long as the plug fits and it has a rating of equal or greater amperage, same voltage, equal to or greater watts then it will work. Those variable voltage multi plug ones they sell at k-mart work but I've never had one that lasted long.
Posted on Aug 06, 2008
CDD ERROR: 102
Carol,
Did you find a fix to this problem? My dp-03 is giving the same error message and ALL my searching has led me to your posts.
Seems you haven't had a response. An authorized TASCAM repair center says it would be cheaper to buy a new one than have it repaired, but that seems NON-sensical to me.
How can An operating system error fix cost more than all the hardware in the unit?
TASCAM is about to lose MANY points with me, a PortaStudio user since the mid 1980's.
I purchased this unit as a close out, as is, and it has NEVER functioned since purchase.
Carol, please, PLEASE, tell me you found a fix.
Jeph O.
Apr 17, 2014 | Tascam DP03 Portastudio Multitrack...
Why does the screen read "device error" when I turn it on?
http://is.gd/B05L6B
According to the user manual for the device, on page 81, it reads:
If any of these errors occur, turn the the unit power OFF and restart it.
If these error message continue to appear, please contact a TASCAM Service Center.
***Device Error*** (the one you're asking about)
FileErr
FX Busy
FX Rx Failed
I
/F Error
Mount Error
SaveParam Fail
SD-Card Error!
SD Not Found
SD Read Busy
SD Write Busy
Looks like your unit may require servicing at an authorized Tascam service center.
Good Luck!!
Oct 12, 2013 | Tascam DP-03 DP03 8-Track Digital...
Glass stove top error message wont go out, wont turn on?
What is the model number of your unit?
What is the error code?
Nov 22, 2012 | Kitchen Ranges
Getting error message
turn off printer while holding #9 button press power wait till display "full nv reset" problem solve
Oct 05, 2012 | Epson WorkForce 845 Wireless All-in-One...
Turned on printer. It completed its system check fine. One sheet of paper went through the printer with no problem. Then the error message "Paper output slot: the paper is jammed. Clear the paper...
Make sure there is no paper even a small piece of it inside the printer. Open all doors and close, remove and replace cartridges and then power off and power on to printer! Most often its a minor problem can be corrected by these measures!
Sep 03, 2011 | Canon PIXMA MP600 all-In-One InkJet...
When camera is turned on the lens opens and closes several times and then an error message appears: "Turn the power off and on again." When this is done, the camera does the same thing - lens opens and...
Hello
Unfortunately a "lens error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Oct 20, 2010 | Sony Battery (844986068551) for CyberShot...
Media error 0 shut down displays when unit is
while the machine is off mode, hold down track edit and shutdown buttons. then power on while holding these buttons. an option to to reset will come up, let go of the buttons and select "yes".
This will reformat your entire hard drive, and you will lose any music you were working on, but it becomes operational again. Or you can send it in to Tascam and let them try to bring it back, if you don't want to lose any material.
Hope this helps :)
-Chenoa Desiree
May 03, 2010 | Tascam X9 DJ Mixer System
I have a Tascam DP-01fx/cd that after powering on it reads sreset error :12 please power off. How do I fix this so I can use the machine again?
Jan 02, 2010 | Tascam DP01 All-In-One Recording Package...
RTs00c00e00 ERROR MESSAGE, WILL NOT PLAY TURN OFF OR EJECT. TRIED TURNING POWER OFF AND UNPLUGGING, SAME ERROR MESSAGE COMES UP. PLEASE HELP! NOT IN MANUAL.
I just turned on my Sony MDS-JE520 and got the same error message RTs00c00e00. Didn't wanted to play MD, but did throw out the MD. After turning it on and off still got the same message. When I took the remote and pressed the key display, it came back to the normal "mode". Everything works again, so hopefully it stays with only this one-time incident.
Hope it will help you guys also.
Regards, Danny
Nov 23, 2009 | Sony MDS-JE330 Mini Disc Player
Tascam DP01 All-In-One Recording Package Microphone Logo
124 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
