Sharp ar 205 printer Refill
How do I refill toner? Cartridge is Ar 200td. I have cartridge out of printer.
Thanks
Aj
  • 29 Answers
On front of this unit is a waste container with 3 screws , remove the screws and empty the waste unit my moving the trap door on the top of the unit as you shack it out over a trash can ,then you will see a plug about 1.5 inches on the toner unit , pull the pluge , be carfull not to damage it , fill it up and put it back together, toner should cost about $20 on ebay
Posted on Mar 10, 2009
I want to know the solution to a sharp ar-5316 i refilled the toner after the toner was empty and the red triangle is still blinking, what should i do?
Does the toner cartridge have a electronic chip on it? if so you could refill it all day long it would not change once the chip say the i am done the cartridge is done. Sorry.
Try this site as a start and get a new OEM cartridge
http://olsonbros.com/sharp/parts/list.htm
Jan 28, 2016 | Sharp Ar 5316
Tip
How to avoid U2 error which require you to replace toner chips.
This tip is proven in our machines could it be AR, ARM or AL series. To avoid the error above refill the toner cartridge ahead of time before the triangular dots(toner low warning in red light) gives warning. Just estimate the level of toner by checking your page count from previous refill. Failure to do so will require you to replace the crum chips or the entire toner cartridge.
on Jul 20, 2012 | Sharp AR-M205 Copier
How to refill my sharp 5316 copier cartridge
inteletgjy.en.made-in-china.com/.../China-SHARP-AR5316-TONER- CARTRIDGE
Feb 24, 2011 | Sharp AR-5316 Advanced Digital Imager...
How do i refill toner cartridge for sharp ar-123e?
Pull out the toner cartridge and you will see a small lid on the gear side of cartridge and open it, then refill with a funnel provided with the toner bottle.
Oct 26, 2009 | Sharp Office Equipment & Supplies
SHARP AR-203 copier unusable after refill
Change the unit chip or reset him.
Sep 01, 2009 | Sharp AL 1631 Copier
Sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Apr 20, 2009 | Sharp Office Equipment & Supplies
Add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Oct 31, 2008 | Sharp AR-5316 Advanced Digital Imager...
Problem with Sharp AR 337
are you refilling the toner cart? if yes..
An easier way is to take out the whole developer unit. Pull down green handle as if you were replacing the toner, there is to the lower right of the developer unit a white handle that if you move to the right will allow you to remove the DV unit. Then there are 5 or 6 screws around the top edge that will allow you to remove the top and manually refill it there instead of trying to refill the cart and making a bigger mess.
Hope that helps...
Jun 20, 2008 | Sharp AR-M237 Copier
66 people viewed this question
k24674
jasbo
jasbo
